auger will stop/wont throw snow????????? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-14-2015, 05:14 PM Thread Starter
Angry auger will stop/wont throw snow?????????
hello'
toro ccr 2450 (38413) year 2001
put new blades,scraper,belt on.
auger will stop where it should plow right through. auger and belt will stop but engine pulley still moves.engine is not bogging down. its either the belt (95-6151) or the auger pulley. is their a shorter belt? auger pulley worn ?
i will tip forward so paddles will hit ground and they will stop.
any info will help..........
and its not the shear bolt!
patmil is offline
post #2 of 8 Old 02-14-2015, 05:57 PM
Likes (Given): 1880
Likes (Received): 661
is the belt routed correctly
post #3 of 8 Old 02-14-2015, 06:20 PM
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Thats what my 2450 was do in. On mine the auger housing is all bent up and rot. The blades are locking up on the housing.
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #4 of 8 Old 02-14-2015, 06:26 PM Thread Starter
yes
belt is routed correct. bottom housing is new. auger spins freely by hand.
patmil is offline
post #5 of 8 Old 02-14-2015, 06:30 PM
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
Question
Does the pulley sit on a key?
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
post #6 of 8 Old 02-14-2015, 07:01 PM Thread Starter
engine pulley has keyway with two set screws.
dont know about auger pulley. have to check. what are you thinking??humm
patmil is offline
post #7 of 8 Old 02-14-2015, 07:05 PM
Likes (Given): 1880
make sure the bolt holding the auger pulley didn't come loose and check the tension on the belt when the bailer bar is engaged
post #8 of 8 Old 02-16-2015, 05:59 PM Thread Starter
Well I bought a new belt and it works. Must of got a belt that was sitting in the back room for a couple years.
patmil is offline
