Stalling problem - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-21-2015, 12:18 PM Thread Starter
Stalling problem
hey guys, my toro 724 (1979 model) is stalling out on me. It starts fine, runs and throws good for about 2 minutes and will just stall out. It starts up again with little difficulty. With no load and the auger running it will run longer, but eventually will stall. It seems to be starving for gas. I have removed the carb and cleaned it out good, blew air through all the openings and that has not helped. It's a Tecumseh engine, 7 hp.
Gas lines and all of that looks good. The needle valve did not appear worn or dirty. What am I missing?
gccch is offline
post #2 of 10 Old 02-21-2015, 12:57 PM
It is possible the valves need checked out. Sometimes they swell up when they get hot and don't close all the way.
post #3 of 10 Old 02-21-2015, 01:00 PM
Likes (Received): 42
Make sure your gas cap is venting properly. Try running with the cap off..if it doesn't stall, replace the cap. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #4 of 10 Old 02-21-2015, 01:03 PM
Likes (Given): 1885
Likes (Received): 663
could be the vent in the gas cap is plugged. when did you last replace the fuel line, if old they could be collapsing on the inside
post #5 of 10 Old 02-21-2015, 01:17 PM
Thanks (Given): 590
Likes (Given): 4368
Likes (Received): 1742
I wouldn't trust the way the fuel line looks. It might be falling apart inside and restricting flow. It's a cheap and fairly easy replacement.
post #6 of 10 Old 02-21-2015, 02:33 PM Thread Starter
Ahahaha... This has to be it. I did not mention my gas cap fell apart on me with one piece falling into the tank which I fished out. But the cap assembly is no longer complete and so I will get a new cap. I should have figured this out. It began stalling around that time also, but since my belts were also failing I focused on those first and forgot all about the cap. Fuel lines were changed a couple years ago so pretty sure those are good.
Thanks!
gccch is offline
post #7 of 10 Old 02-21-2015, 02:37 PM Thread Starter
Just found this
gccch is offline
post #8 of 10 Old 02-21-2015, 03:18 PM
Thanks (Given): 590
Likes (Given): 4368
Yup, I was just going to post that.
post #9 of 10 Old 02-21-2015, 06:14 PM
If the gas cap doesn't help, try to ricehn the mixture a bit but turning out the main jet on the bottom of the carb.
Honda HS55K2
Toro 826OE
bosco659 is offline
post #10 of 10 Old 02-21-2015, 07:48 PM
Thanks (Given): 30
Thanks (Received): 40
For now just put a pinhole in the cap with a tiny drill bit like 1/16" and it will work fine.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
