Plow for the 524? - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 03-03-2015, 12:24 AM Thread Starter
Plow for the 524?
Hi all, season is almost over. Before winter started :
I put in a new augur belt, and made and installed impeller paddles from an old tread mill.
First snow was wet and slushy, and the 524 did NOT perform well, ice up.
All the other storms, I was very happy, it was throwing 30 feet and had not iced up again, great for only 5hp. Which brings me to this question,:
Have any of you made a plow to attach to your blowers when its slushy? I am thinking of plywood covered with trim coil maybe. A plow I can angle easily and quickly. Any suggestions? I don't want to buy a plow.
silwan is offline
post #2 of 12 Old 03-03-2015, 06:02 AM
Likes (Received): 42
Diytips.info has a homemade plow on YouTube..there are others there as well. They seem to be most effective on light snow. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #3 of 12 Old 03-03-2015, 09:45 PM Thread Starter
Thanks for the reply, I will take a peak.
silwan is offline
post #4 of 12 Old 03-03-2015, 10:12 PM
Thanks (Given): 30
Thanks (Received): 40
Just note that you need stiff rubber for an impeller kit. Flexible rubber won't do much, it needs to sweep the impeller housing clean and not just flex out of the way anf bypass the slush building up in there.
You may just want to get an old stiff mud flap and cut some new pieces and just replace them, would be an easy swap out and then your impeller kit would perform as intended.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #5 of 12 Old 03-03-2015, 10:22 PM
they actually made a plow kit for these 24 inch blowers, not sure if its stills available. Toro 38080 Parts List and Diagram - (9000001-9999999)(1979) : eReplacementParts.com
post #6 of 12 Old 03-03-2015, 11:03 PM
Thanks (Given): 585
Thanks (Received): 761
Likes (Given): 4312
Likes (Received): 1715
I don't have one but I thought the photo was interesting.
Name:	Plow on Craftsman blower.jpg
post #7 of 12 Old 03-04-2015, 09:09 AM Thread Starter
I may do that in the off season, thanks.
silwan is offline
post #8 of 12 Old 03-04-2015, 09:13 AM Thread Starter
That's a nice picture. Professionally done.
silwan is offline
post #9 of 12 Old 03-04-2015, 09:14 AM
Thanks (Given): 585
Likes (Given): 4312
If you were creative you could make one that when down worked as a plow and when pivoted up was a drift breaker and just stayed on the machine 24/7.
Silwan, it would be helpful if you added a location to your profile.
post #10 of 12 Old 03-05-2015, 01:23 AM Thread Starter
That is a good idea. By the way I am in Northern NJ. We are getting more snow today, and had slush conditions yesterday, rain snow sleet, a nice mess in the driveway. The plows left huge round mounds at the driveway entrance.
But I have to say and take back some things; The 1st snow of the season was wet and heavy and the 524 iced up. But that was not the machines fault, but mine. I had put a new belt on, and it was not adjusted properly. I made adjustments after that 1st snow.
The paddles I put on the impeller are stiff ( stiff layers of tread mill belt glued together into 1 solid paddle). So yesterday, I was pleasantly suprised as it threw the slush with no problem, ya was my expression.
I am 6'2" and I wish the bars were a little higher, boy it's a heavy machine, but I am pleased.
silwan is offline
