toro 5/24 question - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 07-01-2015, 02:09 PM Thread Starter
toro 5/24 question
i recently picked up a toro 5/24 that has a hard time getting the lever into 1st gear also there is no reverse any ideas on what could be causing the problem? thank you!
toroboy is offline
post #2 of 4 Old 07-01-2015, 04:05 PM
Your Toro will be set up slightly different than these, but same concept. The moving parts are binding and need cleaned and oiled. The reverse issue is probably an adjustment. While most blowers put the friction disc on the opposite side of center for reverse, those old Toros used a separate disc on the back side.
Thanks toroboy thanked for this post
Likes DaHen, toroboy liked this post
post #3 of 4 Old 07-02-2015, 05:49 AM
Likes (Received): 1378
you are going to have to remove the service panel. and clean the friction wheel slide bar. and check to see if the shift rod is bent or has be modified in some way. let me know the score on that 1.
Likes toroboy liked this post
post #4 of 4 Old 07-02-2015, 02:09 PM Thread Starter
thanks guys yep that was it the bar was very dirty as it looked like the service panel was never removed!
toroboy is offline
