Power max 826 LE-auger removal - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 09-20-2015, 05:28 PM Thread Starter
I just bought a 10yr old machine. I removed the 2 shear bolts from the impeller shaft but the auger won't slide off the shaft. Is there something else, I cannot see, holding it on or is it just likely rusted on there. Any tips for removal? I would like to some scraping and repainting.
thanks!
sabresfan is offline
post #2 of 6 Old 09-20-2015, 06:40 PM
Thanks (Received): 379
Likes (Received): 1362
You are going to have to split the machine in 2. and undo the impeller bearing assm. then pull it straight out. then you will be a proud parent of a bouncing baby auger and impeller assm. MAZEL TOV on that 1.
post #3 of 6 Old 09-20-2015, 09:33 PM Thread Starter
oh dang ok so I should stop trying to yank the shaft out of the pulley? I took the plastic chute off so i can see the pulley. i removed the 2 set screws I assumed were holding the shaft in the pulley. What is holding the shaft in the pulley?
post #4 of 6 Old 09-21-2015, 12:02 AM
Almost all blowers have need the belt pulley on the back removed to pull the front gearbox out of the blower. This normally requires separating the drive section from the blower section.
https://www.youtube.com/user/donyboy...?query=gearbox
post #5 of 6 Old 09-21-2015, 10:35 AM Thread Starter
after spending all night on youtube I did see where it appears the pulley is pressed on. I don't think I want to mess with it to that extent. I will probably button her back up and fix the rust best I can. I like my Honda......eeeeeeeeaaaaaaaasssssssssssyyyyyyyyyyy auger removal
post #6 of 6 Old 09-21-2015, 06:32 PM
just take a 3 jaw puller after it.
