0W/30 or 5W/30 synthetic in new Toro 826 HD OXE - Snowblower Forum : Snow Blower Forums
post #1 of 31 Old 10-05-2015, 01:45 PM Thread Starter
Hi,
I just bought a new Power Max HD 826 OXE which recommends SAE 0W/30 synthetic oil (38913), which is different than the traditional B&S SAE 5W30 snowthrower rated oil I have been using in my 1988 Toro 824 and 2011 Troy-Bilt 2620.
At least from the Toro charts, the Synthetic 5W-30 is rated above 104 degrees F and below -22 degrees F, but was wondering if anyone knew if the Toro HDs really benefited. On the face of it, as long as I stay with a synthetic I should be fine.
Given that I am in New England and, does anyone have a recommendation one way or another with this engine, particularly given that SAE 5W/30 synthetic is much more available? It would also simplify maintenance by allowing me to standardize on one oil type.
Thanks!
laptopquestions is offline
post #2 of 31 Old 10-05-2015, 02:06 PM
Thanks (Given): 102
Likes (Given): 273
I'd probably run their recommend oil while the unit is under warranty.
Welcome aboard, Laptops!!
uberT is offline
Likes MPCOA, Kiss4aFrog liked this post
post #3 of 31 Old 10-05-2015, 02:41 PM Thread Starter
I separately sent Toro an email specifically asking this question. It will be interesting to see what they say
In the meantime, certainly appreciate the feedback and thanks for the welcome!
post #4 of 31 Old 10-05-2015, 05:01 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
Welcome to the forum
Except for the warranty consideration it's why I switched to Mobil 1 0-40
Works great in almost everything. I get it at Walmart.
Name:	Oil mobil 1 european formula.jpg
post #5 of 31 Old 10-05-2015, 05:13 PM
Thanks (Received): 173
Likes (Given): 415
Likes (Received): 664
Originally Posted by laptopquestions View Post
Hi,
Thanks!
thats interesting as i thought it was a big " no no" to run a new engine with synthetic oil until after its recommended break in period ( first oil change) ???? or did the unit come with dino oil in the sump and you are thinking ahead?
post #6 of 31 Old 10-05-2015, 05:20 PM
Likes (Received): 483
post #7 of 31 Old 10-05-2015, 05:42 PM
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
I would try to use the 0W-30 if that is what Toro recommends for the Loncin engine. However the difference between the two is not much, either one in a synthetic should work fine. I would not be concerned about a synthetic 5W-30 being too thick for any conditions you may encounter. If you can get a Toro tech rep on the phone I assume they will advise you that you can go with either one.
Last edited by Cardo111; 10-05-2015 at 08:33 PM. Reason: Edited post based on thread details
Cardo111 is offline
post #8 of 31 Old 10-05-2015, 06:47 PM Thread Starter
Have no idea, but I will ping the dealer tomorrow to find out what they used in the initial setup.
The whole thing that got me started questioning things in the first place:
Power Max® HD 826 OXE (38805)
Manuals -> Parts Catalog
Operators Manual (3396-745.pdf) - Page 46
Attachments and Accessories
For 38805 Power Max Heavy Duty 826 OXE Snowthrower
Product Name Model/Part
Weight Kit ......................................107-3815
26in Drift Breaker...............................107-3816
Heavy-Duty Skid Kit..............................125-1104
Snow Cab Kit ....................................127-5960
Non-Marking Skid Kit ............................38211
Tire Chain Kit, for 16in Tires...................38215
Toro Snow Oil 0W30 Synthetic 20-Ounce Bottle ....38913
Toro 2-Stage Cover...............................490-7466
Plain 2-Stage Cover..............................490-7467
post #9 of 31 Old 10-05-2015, 07:15 PM
Thanks (Received): 33
Likes (Received): 54
I've always run Rotella or M1 EP after the break in period.
mobiledynamics is offline
post #10 of 31 Old 10-05-2015, 07:19 PM
honestly i would run royal purple 5w30 after break in
