Toro 824 Model: 38080 (1990) Carburetor / Engine Issue - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 11-16-2015, 10:59 AM Thread Starter
Hey guys, I put fresh oil in my Toro this weekend to prepare for the coming winter. Gased it up with gas Ive been using all summer for my mower. I use Sta-bil fuel stabilizer (Marine Grade Blue). Fired her up with only a couple pulls to start. After about 5 minutes running rough, it died. I have only been able to keep her running now mostly choked ( #1 = Full choke, #4 = No choke, I was on choke setting #2) and with the auger running. I can see the governor / throttle rods moving while its surging. I was having similar problems late last winter but seems to be worse now. Im concerned I have leaky intake / exhaust valves requiring that I pull the head, pull & clean valves, use the grinding past etc. I watch Donyboy and think I have classic symptums. Not sure I can do this work myself. Maybe I have carb issues also though? Only thing left is fresh gas.
Engine Tecumseh HM80-155291P
Carb 632334A
Here are issues:
- Cant turn the choke off and keep her running.
- When running choked, The muffler is popping, blue flames, red sparks. Was getting this last year without choke.
- The muffler bolt area was glowing hot. This issue is new.
Heres what Ive done:
- Pulled off the Carb bowl & cleaned with carb cleaner.
- Pulled appart the main jet & cleaned with carb cleaner. Got the 2 tiny holes and the side of the jet with cleaner and wire.
- Sprayed carb cleaner up into the carb where main jet goes.
- Sprayed carb cleaner all around the float hinge area.
- Replaced the bowl gasket and main jet gasket
- Pulled out the idle mixture screw & cleaned with carb cleaner
- Adjusted the main jet 1.5 to 1.75 turns out, Adjusted the idle mixture screw 1 turn out.
ts8169 is offline
post #2 of 8 Old 11-16-2015, 11:08 AM
do you hear a lot of air escaping when you pull it over slowly by hand?
post #3 of 8 Old 11-16-2015, 11:43 AM Thread Starter
Anywhere in particular that I would hear this? Or where the air would be escaping? I'm a novice at this stuff.
ts8169 is offline
post #4 of 8 Old 11-16-2015, 12:01 PM Thread Starter
I did notice air coming from the engine head, adjacent to the oil dipstick at the front of the machine. I will say the muffler has seem it's days and the muffler gasket could be replaced with muffler.
Name:	Toro 38080 1990-0000001-0999999 Engine Assembly Issues.jpg
ts8169 is offline
post #5 of 8 Old 11-16-2015, 12:29 PM
Likes (Given): 1632
That's likely the air produced by the flywheel / fan being forced across the top of the head...through the cooling fins.
post #6 of 8 Old 11-16-2015, 04:00 PM Thread Starter
[QUOTE=classiccat;748754]That's likely the air produced by the flywheel / fan being forced across the top of the head...through the cooling fins.[/QUOTE
Yup, that makes sense. No issue there then.
Anyone try spraying carb cleaner into the gas? Or spray carb cleaner into the choke while running? Maybe I'll just pull the carburetor off and soak the whole thing for a day or 2.
ts8169 is offline
post #7 of 8 Old 11-16-2015, 04:58 PM
you may have a bad head gasket. put some powder(flour,baby powder, whatever) in between the head and the block and pull it over. if the powder blows away, your head gasket is bad. i would also recommend checking the valve clearances if you are going to tear it down that far
post #8 of 8 Old 11-21-2015, 08:30 PM Thread Starter
So I went back into the carburetor and disassembled the main jet, The o-ring didn't look too good so I bought a couple new ones and replaced in the main jet and idle mixture rings. Ran both of these threads through a wire wheel to clean. I've read in this forum that a glowing muffler could indicate running lean so when I replaced the jet I set at 1.75 turns out. Idle screw at 1.25 turns out.
Also checked spark plug & looked good. Looking through plug hole, the Intake valve looked dark but exhaust looked ok. Neither valve looked to be sticking. The inside of the gas tank looked questionable so I sprayed some carb cleaner and wiped the inside with a rag/ long screw driver. Got some FRESH gas and treated with Sta-Bil right away, marine grade. Then I fired her up. Sure enough, surging as usual, for a good minute+. Smoke came out the muffler and shot toward the auger (muffler and gasket are bad) Then suddenly everything leveled out. So I turned the choke back a notch, and then off. Motor was purring real nice.
ts8169 is offline
