1990 Powershift 828 Light upgrade - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-21-2016, 06:42 PM Thread Starter
Hello all,
I just picked up a 1990 Toro Powershift snowblower for $75.00. This thing runs very well and looks to be a good buy. I wanted to see about upgrading to a set of LED lights rather than the kit Toro made. I've read the upgrade light thread by Superedge88, but still wondered if I have the necessary stuff to start the project (ie. the alternator/stator).
It is a model 38570, serial number 0000000272 with a Briggs and Stratton 8hp engine. The engine has a small white fitting that extends out and appears to be a stator.
My question is whether or not that fitting will allow me to start the process of getting the LED lights, bridge, etc. Is there a way to test the output before buying the necessary stuff?
Thanks Brian
Bjake is offline
post #2 of 13 Old 01-21-2016, 06:50 PM
Thanks (Given): 511
Thanks (Received): 682
Likes (Given): 3849
Likes (Received): 1479
to the forum Bjake
You sir got a heck of a buy !! You will be well hated by all of us that paid much more thinking we were getting the deal The engine is worth more than that !!
Yup that's the wire. You lucky dog, that Briggs should be a 5 amp AC system so you have room to add hand warmers if you want. They usually run around 30 watts.You'd be safe with 20-30 watts of lighting.
That system should handle 60-70 watts total. Hand warmers can be AC so you'd only need to run the LED(s) on a rectifier.
I purchased my LED flood from Ebay.
ID:	73921   Click image for larger version
Name:	LED flood lights  1a.jpg
post #3 of 13 Old 01-21-2016, 07:00 PM Thread Starter
30 watts - Does that mean I have to get two lights that add up to 30 or less? For instance I see on ebay a couple of nice 18w led cree lights, but would they be too much for this system?
Bjake is offline
post #4 of 13 Old 01-21-2016, 07:11 PM
Thanks (Given): 511
Likes (Given): 3849
I'm conservative when figuring out things.
That AC system will likely be closer to 14 volts or even a little more.
In my Toro book it lists that Briggs with a 5 amp system. 14 volts x 5 amp system equals 70 watts.
The hand warmers might be a little more or less you need to figure out if, and if what you'll get and what they draw.
You can run four 18 watt lights without the hand warmers on and turn two, three or all off and run the hand warmers alone. But at least two off with the hand warmers, 18w + 18w + 30w.
That 18w flood is just a suggestion. I like them and they're pretty cheap but you should look around at other installs to see if someone has something better.
Wow $75 . . . . I thought I got a great deal on my PS1332 but you've blown me out of the water with this one.
I'm still trying to find an upgraded charging system for mine but the flywheel used is about a hundred and another fifty for a used coil
The Toro site is great for looking up diagrams and manuals: https://www.toro.com/parts-yardtools...FQEdaQodffACPA
You might buy from them or take the part number and shop the web for price and availability.
post #5 of 13 Old 01-21-2016, 07:16 PM Thread Starter
Thanks,
I just wear gloves, so I don't have to worry about hand warmers. I do want to get the brightest lights I can though. I'll try the 18w floods and see how they go. I found them on ebay for about 20.00.
Bjake is offline
post #6 of 13 Old 01-21-2016, 07:20 PM
Thanks (Received): 157
Likes (Given): 1638
Welcome to SBF!
Hats-off to you sir! What a deal!
classiccat is online now
post #7 of 13 Old 01-21-2016, 07:20 PM
Thanks (Given): 511
Likes (Given): 3849
Two for $18 shipped. http://www.ebay.com/itm/TOP-4INCH-2X...dWoHVJ&vxp=mtr
I went with this style because others have really liked them. I was surprised when I received them how heavy they are and they seem well built.
If you think of watts as money you have 70 watts to spend so if you wanted you could do two 30 or 35 watt lights
That would be BRIGHT !!
post #8 of 13 Old 01-21-2016, 07:35 PM
Likes (Given): 368
Likes (Received): 597
Originally Posted by Bjake View Post
Thanks,
from seeing what other members here have done with stator powered led lights.....two of those will turn night into day.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #9 of 13 Old 01-21-2016, 09:20 PM
Grunt's Avatar
Thanks (Given): 248
Thanks (Received): 288
Likes (Given): 2901
Likes (Received): 537
Don't forget to add the rectifier to the circuit. LED's don't like AC voltage.
post #10 of 13 Old 01-22-2016, 07:02 AM
Thanks (Received): 353
Likes (Received): 1163
There never was a hand warmer op. on those POWERSHIFT'S. I don't even know about aftermarkets.
