1128 OXE Conversion to heated grips-OHXE owners HELP... - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 01-24-2016, 12:05 AM Thread Starter
hfjeff's Avatar
Likes (Received): 13
I have a 1128 OXE and would like to add the heated hand grips. I have the grips and handle part numbers, but I have been told my alternator will not power both the headlight and the heated grips. Im having trouble locating the part number for the alternator that comes with the OHXE and also the power switch for the heated grips. Does anyone know what the Toro part number is for the alternator that I need or can somebody with a 2014 1128 OHXE provide an engine model and type? It is stamped on the side of the valve cover and should look something like this. I apologize if this has already been covered as I searched the forum and did not find a post on it.
hfjeff is offline
post #2 of 27 Old 01-24-2016, 08:11 PM
Thanks (Given): 511
Thanks (Received): 682
Likes (Given): 3849
Likes (Received): 1479
to the forum hfjeff
I turned your photo for you. It would be MUCH easier if you just posted the numbers since it's still hard to figure out if I'm seeing a 3 or an 8 in the "Type".
Does the engine say 16.50 on one of it's stickers, the recoil ??
I'm pretty sure it's a 1.5 amp but I'm not positive.
Maybe someone else knows. I was looking here https://www.briggsandstratton.com/us...T=21M314-0128*
There are higher amp options in the part list.
post #3 of 27 Old 01-24-2016, 08:58 PM
Likes (Given): 23
Likes (Received): 218
I had the same issue with an under-powered generator, so I put in switches so that I can run either the HHG, the lights, or nothing, or both under reduced lighting and heat - but never use that option.
RIT333 is offline
post #4 of 27 Old 01-24-2016, 10:58 PM Thread Starter
hfjeff's Avatar
Sorry, I forgot to add some critical info. The motor is a Briggs and Stratton 342cc and 16.5 ftlbs torque. I believe you are correct that the current alternator is 1.5 amps. I understand that I can install a switch and use one or the other, but being and engineer type, I want make it fully functional. I am getting the OEM heated grips, new handles for the auger and drive, and switch and harness.
I am quite mechanically inclined so changing the alternator is no big deal. I just need to know which one to purchase. I was hoping someone with an OHXE and the Briggs 342cc 16.5 motor could take a look at their numbers so I could research which alt is in their machine.
Any help is greatly appreciated.
hfjeff is offline
post #5 of 27 Old 01-25-2016, 04:56 PM Thread Starter
hfjeff's Avatar
I worked with a local Toro Dealer who was very patient and thorough and I believe he found everything to piece this together. Unfortunately Toro does not make a kit like Ariens does so you have to gather the individual pieces. Everything is on order and I will post an update as to how it goes. It is fairly expensive if you have to change the alternator as I do.
hfjeff is offline
post #6 of 27 Old 01-25-2016, 05:17 PM
Thanks (Received): 353
Likes (Received): 1163
Briggs motors only have stators on them. with a alternator u need a voltage regulator. that is my take on it any way. but as you all know I have been wrong before. here is a tid bit get some rechargeable bike lights. and use the other to keep your paws toasty warm
post #7 of 27 Old 01-25-2016, 05:49 PM
Thanks (Given): 511
Likes (Given): 3849
Most heated grips run around 30 watts so if you're only pumping out 18 on a good day you'll likely be very disappointed in what heat you get. That's if it's noticeable at all.
My machine, I'd go for one of the better coils that should fit in there so you're getting at least 3 amps, 5 if you need to run lights and warmers on a cold dark winter night.
post #8 of 27 Old 01-25-2016, 05:54 PM
Thanks (Received): 112
Likes (Received): 292
You have the 793640 1.5 amp DC only in there now if the parts list is correct. Which one are you changing over to? Just curious because I am considering the same change, to get more electrical power from the existing engine. Did the dealer tell you if the existing flywheel with the small magnet is compatible with the new stator?
Just for your reference, you might want to look at the following link which has a useful pdf file attached.
http://web.missouri.edu/~schumacherl...ylinderOHV.pdf
Work fascinates me.
skutflut is offline
post #9 of 27 Old 01-25-2016, 11:25 PM Thread Starter
hfjeff's Avatar
The dealer looked up a replacement motor for an 1128 OHXE and then was able to research the alternator that came with that motor. I believe the replacement he ordered is either a 5A or 9A. He also compared the part numbers of that motor's flywheel and mine and found that they are the same. Hopefully he got it right. I do not know what the part number is yet as he just ordered them today over the phone. But I should have the parts by this Saturday hopefully.
I had an Ariens Deluxe 28 that came with the headlamp but no heated grips and I just ordered the Ariens kit and hooked it up and they worked great. I had no issue with a dimming headlamp and that was on a small 250cc Briggs. Too bad Toro is not quite as accommodating.
Fortunately I am persistent!
hfjeff is offline
post #10 of 27 Old 01-25-2016, 11:46 PM
You put ariens grips on the airens, correct? Did it have a dedicated power point for the grips? I have a Briggs chart showing a whole whack of different stators with AC, DC, AC/DC, outputs, and alternators up to 60 amps for some of their engines. They are a bit vague on specs in places, and what flywheel goes with what.
Please post your results when you get the new stator on and the grips wired up. Let me know the P/N of the stator you got when its all working. Thanks
Work fascinates me.
skutflut is offline
