521 auger runs nonstop - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 03-25-2016, 10:14 PM Thread Starter
Hi everyone, I have a Toro 521 that I'm having problems with. It was serviced in Sept, including both belts. I recently noticed that as soon as it is started, the auger begins to turn. The throwing power seems to have decreased also. The company that did the work is now shutdown and the new owner doesn't have time for the next few weeks to look at it. I looked up the belts and it has the right ones on. Any help you can give would be great! This was my stepfathers and was given to me when he passed. He would always do all of the neighbors walks and I want to keep up his tradition, so I need it running asap! By the way, love the forum!
ColoJeeper is offline
post #2 of 17 Old 03-26-2016, 08:38 AM
Thanks (Given): 135
Thanks (Received): 266
Likes (Given): 358
Likes (Received): 900
There is an adjustment for your machine.
micah68kj is offline
post #3 of 17 Old 03-26-2016, 04:36 PM Thread Starter
Was hoping that was the case, but also hoped for a little more help on which setting and how to fix it
post #4 of 17 Old 03-26-2016, 04:53 PM
I believe the bolt on the idler pulley is slotted. You can loosen the bolt and lower the tension on the belt and then tighten it back down. Have a look through these videos.
https://www.youtube.com/user/donyboy...ry=belt+adjust
Your description of the problem is odd though. If the auger keeps turning that means the belt is too tight. If the throwing performance is bad that means the belt is slipped and too loose...
Does it seem like the belt is slipping or does it seem like the engine itself is bogging down?
Thanks ColoJeeper thanked for this post
post #5 of 17 Old 03-26-2016, 08:22 PM Thread Starter
Thanks for the link, I actually watched this one yesterday while I was trying tougher it out. Mine doesn't adjust and like that one though. I went after some lighter snow today and it seems to be throwing it like it should. So, I guess the main issue is that the auger runs when it shouldn't and the belt is not slipping. The numbers on the belt match what Toro requires.
One thing that I noticed today is that attached to the pulpy that moves forward when you squeez the handle is what appears to be like a small brake pad. It sits against the bottom pulpy until you squeez the handle. Any thoughts?
post #6 of 17 Old 03-27-2016, 09:45 AM
Thanks (Received): 112
Likes (Received): 292
That brake pad should be on the OUTSIDE, flat part of the belt, not between the belt and the pulley. When you release the clutch to stop the auger, the brake pad should land on the flat side of the belt and pulley to stop the auger. If you have the belt running against the outside of the brake arm, between the V part of the belt and the pulley, the first thing that will probably happen is your belt will get shredded, plus there will not be enough slack on the belt to let the auger stop as the slack is being taken up by the brake arm in the wrong place. Actually, the belt is in the wrong place in relation to the brake arm.
Work fascinates me.
skutflut is offline
post #7 of 17 Old 03-29-2016, 10:14 PM Thread Starter
thanks, I guess I should clarify. The thing that looks like a breakpad is on the outside of the pully (not sure why autocorrect changed to pulpy). Is this something that can be replaced or adjusted?
post #8 of 17 Old 03-30-2016, 04:49 PM
Correct me if I am wrong, but is the brake you mentioned attached to the same plate as the idler wheel, at the opposite end? When the clutch is engaged, the idler wheel puts pressure on the belt, and the brake pad moves away from the pulley?
Can you get a good photo of the part and post it? The brake pad is supposed to run on the outside of the pulley, but the belt also has to be on the pulley so that the brake hits both the pulley and belt. If the brake is on the pulley but the belt is on the back side of the brake, not in the pulley where the brake is hitting, that's a problem
Work fascinates me.
skutflut is offline
post #9 of 17 Old 03-30-2016, 09:00 PM Thread Starter
Not wrong at all! That is exactly how it looks, but it appears as though that pad isn't either making a strong enough contact or is worn out. Can I change it?
post #10 of 17 Old 03-31-2016, 08:23 AM
Thanks (Received): 341
Likes (Received): 1107
You know if you posted some pics of this problem that is presenting itself onto us. I just might be able to figure it out.
