824 power shift 38540 won't throw snow - Snowblower Forum : Snow Blower Forums
Old 10-06-2016, 03:56 PM Thread Starter
Hey all
I acquired a power shift 824 model 38540 last winter and only used it once. While trying to use it the machine had no problems with the auger turning but it only threw the snow right in front of the machine barely reaching the top of the shoot and eventually just packed the snow tight to the fan.
Any ideas what would cause this? Trying to get an early start on repairing before the snow comes
Thanks for the help in advance
-Doug
74chevy4life is offline
Old 10-06-2016, 04:03 PM
Thanks (Received): 353
Likes (Received): 1167
You more than likely need new belts. and some adjustments on the belt system. ALOHA from the paradise city. let me know the score on that 1.
Old 10-06-2016, 05:02 PM Thread Starter
I have replaced the belts because when I got it there were no belts on it
Old 10-06-2016, 07:31 PM
Thanks (Received): 157
Likes (Given): 369
Likes (Received): 598
do those machines have some type of roll pins / keyway that could be sheared ?
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Old 10-06-2016, 11:35 PM Thread Starter
If they did have a broken key way would the fan spin freely when the machine is off?
Cause the fan does not spin with machine off
Old 10-07-2016, 07:28 AM
Likes (Given): 1645
Likes (Received): 382
+1 on checking the belt tension. Also make sure the engine is maintaining RPM; is the engine bogging-down when you hit the heavier stuff? Lastly, consider doing an impeller modification (bolting baler belt to the impeller blades).
classiccat is online now
Old 10-07-2016, 06:53 PM
Post some pic's of this headscatcher for us.
Old 10-07-2016, 06:55 PM
https://www.youtube.com/watch?v=EMAgb3QNEE8
HEY BROTHER CC. on those POWERSHIFTS you really don't need those extra flappers in there.
Old 10-08-2016, 11:09 AM
Thanks (Given): 511
Thanks (Received): 682
Likes (Given): 3849
Likes (Received): 1480
to SBF 74chevy4life
