dog sitter totaled snowblower with her car - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-10-2017, 06:31 PM Thread Starter
it's true, but a long story. it was used twice. 2012 troy bilt 2840. auger was smashed, shaft bent. pulled it apart, got new parts, carefully reassembled. sat a year so drained fuel, cleaned carb, fresh fuel. started, some surging. doesn't throw snow more than 3-4 feet. seems to push snow, making self propel difficult. leaves rows of snow on either side of the auger. i can't figure it out. is it possible to install the shaft wrong? backwards, augers in wrong position? spacers can't move because shaft is drilled for pins. led auger cable properly, has tension. could it just be low power is lowering auger speed? could it be anything else mechanical? please don't say you'll tell me if i tell you the story. actually her dog was behind the wheel when she hit it. also true.
mcrichardson109 is offline
Likes Sid liked this post
post #2 of 8 Old 02-10-2017, 06:38 PM
Thanks (Given): 78
Thanks (Received): 161
Likes (Given): 401
Likes (Received): 641
four piece augers ? sounds like some or all sections are installed in the wrong orientation. a pic would tell the story.
edit....welcome to sbf !
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 8 Old 02-10-2017, 07:12 PM
Thanks (Given): 101
Likes (Given): 264
Likes (Received): 146
M, welcome aboard! What an interesting way of introducing yourself !!
uberT is online now
post #4 of 8 Old 02-10-2017, 07:35 PM
merdody1's Avatar
Truth is stranger than fiction. Time to find a new dog sitter!
Craftsman 9hp/29" 536.887992
Ariens st824 924039 (curb find)
MTD 5hp/24" (curb find)
Toro 521 38052 (traded an exercise bike for it)
merdody1 is offline
post #5 of 8 Old 02-10-2017, 08:57 PM
Likes (Given): 467
Likes (Received): 480
It is likely that you installed all or at least some of the augers backwards......
post #6 of 8 Old 02-10-2017, 10:00 PM
Likes (Received): 303
If they are rolling from top to bottom they need to look like this if it is coming at you
///////0\\\\\\\\
NOT
\\\\\\\\0/////////
If they are rolling from bottom to top, the gear was put in backwards.
post #7 of 8 Old 02-10-2017, 10:15 PM
Thanks (Received): 112
Likes (Received): 297
engine surging and low power is one problem, likely bad fuel or gummed up carb from sitting. You probably have the augers switched from left on right, right on left, pushes the snow away from the bucket instead of gathering it in.
put some photos on photobucket, and post the links here. make sure to get good shots looking straight at the auger.
Don't blame the dog sitter, if the dog was driving.
Work fascinates me.
skutflut is offline
post #8 of 8 Old 02-10-2017, 10:28 PM
Thanks (Given): 14
Thanks (Received): 17
Likes (Given): 36
Likes (Received): 31
Several years ago, my sister in law backed into my brand new Harley. Talk about sickening. Ugh....
250cc B&S (1150 ft lbs)
Loco-diablo is offline
