Right side track keeps locking - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 01-06-2014, 01:34 PM Thread Starter
Hi, I am having an issue with my tracked Troy-Bilt where the right side track keeps locking. I can run the machine for a few minutes and it will go forward and pivot right and pivot left no problem, but then I hear a "click" and the right track locks. If I put it in reverse and then back into forward it will unlock. Also it can lock when in reverse and if I put it into forward it will unlock for a short time. Any help as to possible causes would be great. I have to reverse and forward to unlock many many times while doing the driveway.
Thank you!
ADR1975 is offline
post #2 of 8 Old 01-06-2014, 01:54 PM
Is it possibly loose and coming off the track or maybe has a bad bearing in one of the wheels?
post #3 of 8 Old 01-06-2014, 04:09 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
What is the model#?
post #4 of 8 Old 01-06-2014, 09:51 PM Thread Starter
Hi, the manual number is 772C0767, and when it locks the track and wheels all do not move, but the left track will pivot.
ADR1975 is offline
post #5 of 8 Old 01-07-2014, 01:27 AM
db9938's Avatar
It sounds as though the axle is binding, and the manual number does not allow me to look up the schematics. Is there a general generic number?
Like 4510, or 210?
post #6 of 8 Old 01-07-2014, 08:33 AM
I found a manual. In the end of the manual it has a parts diagram. It looks like there are some chains on the drive train. Each track has a separate chain and drive system. I wonder if one of your chains needed tightened.
[Page 28/52] Manual - Cars - Troy-Bilt 772C0767
post #7 of 8 Old 01-07-2014, 01:14 PM
db9938's Avatar
On page 30, I would also look at #32. It too may also be a source for axle play.
post #8 of 8 Old 01-07-2014, 01:21 PM Thread Starter
Thank you for the replies, I will check the link and noted pages.
ADR1975 is offline
