Leftover part after removing carburetor. - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 03-13-2017, 02:17 PM Thread Starter
I removed my carburetor to clean the the jet. I placed all the screws and such on the fuel tank as I removed them. When I put it back together I was left with this part and I can't remember where it goes.
it measures 3/4 length by 1/4 I.D.
Jason
jayman is offline
post #2 of 10 Old 03-13-2017, 02:28 PM
Thanks (Given): 95
Thanks (Received): 193
Likes (Given): 73
Likes (Received): 444
Maybe you should tell us engine?
post #3 of 10 Old 03-13-2017, 02:29 PM
Thanks (Given): 224
Thanks (Received): 191
Likes (Given): 2016
Likes (Received): 507
Welcome Jason!
some info regarding engine, blower model # & year would be helpful.
it looks like a valve guide to me
('87 Toro 38150 826)
classiccat is online now
post #4 of 10 Old 03-13-2017, 02:42 PM
Likes (Received): 303
It looks like a spacer to me. How much stuff did you take off to get to the carb? Maybe a sleeve or spacer for the starter??? MTD's have that Powermore engine and I know you end up taking lots of shrouding to get to the carb. Just random thoughts without knowing how much you dug into the engine.
post #5 of 10 Old 03-13-2017, 02:45 PM Thread Starter
Sorry. It's a Storm 2620 year 2012. With a Troy-Bilt 752Z370-SUC 208cc engine. I took off the muffler shield, muffler, front plastic panel with the choke and throttle knobs. I removed linkage, fuel hose, and carburetor.
jayman is offline
post #6 of 10 Old 03-13-2017, 02:51 PM
Wonder if the throttle or choke have a sleeve inside there?
post #7 of 10 Old 03-13-2017, 03:37 PM
524SWE's Avatar
Likes (Received): 23
looks like one of the spacers that go inside the shroud over the carb. there's a long and a short one, they fit inside the shroud, over the studs that the carb slides onto, two acorn nuts hold the carb on, the spacers and the acorn nuts work together so you don't over tighten the carb.
1995 Toro CCR1000
2007 Cub Cadet 524SWE
524SWE is offline
post #8 of 10 Old 03-13-2017, 03:48 PM
524SWE's Avatar
here's a picture, I don't remember which side is longer but I think it will be obvious.
Name:	blank page 1 - Copy (2).jpg
1995 Toro CCR1000
524SWE is offline
post #9 of 10 Old 03-13-2017, 05:29 PM Thread Starter
Thank you so much. I was loosing my mind. I couldn't find this part listed anywhere.
Again thank you,
Jason
jayman is offline
post #10 of 10 Old 03-13-2017, 05:58 PM
524SWE's Avatar
your welcome, no problemo! it doesn't show on most parts websites
1995 Toro CCR1000
524SWE is offline
