Troy-Bilt 2460 (Should I add heated hand grips) - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 11-19-2017, 11:09 PM Thread Starter
Likes (Given): 14
Likes (Received): 7
I picked up the 2460, I decided it was worth the extra money over the 2410 because I wanted the airless tires, the longer chute, single grip control and the headlight was a plus.
I see they have a heated hand grip kit for 45.00 and curious if itís worth it.
Anyone add them?
Tumble2113 is online now
post #2 of 11 Old 11-19-2017, 11:16 PM
Miles's Avatar
Thanks (Given): 66
Thanks (Received): 52
Likes (Given): 240
Likes (Received): 139
I'm in Maryland near the bay and it's not cold enough to need handwarmers, usually its around 28F/-2.2C. But in real cold places, the handwarmers are supposed to be great and are worth it.
Miles is online now
post #3 of 11 Old 11-19-2017, 11:45 PM
Cardo111's Avatar
Thanks (Received): 125
Likes (Given): 79
Likes (Received): 168
If you have a large area to clear and you will be out there for awhile it's a nice feature to have.
Cardo111 is offline
post #4 of 11 Old 11-21-2017, 10:59 AM
Thanks (Given): 28
Likes (Given): 157
Likes (Received): 38
You could also buy a case of chemical hand warmers and put them in your gloves. I know contractors often do this in the winter.
jonnied12 is offline
post #5 of 11 Old 11-21-2017, 11:10 AM
Guest
Thanks (Given): 20
Thanks (Received): 54
Likes (Given): 40
Likes (Received): 94
that kit is easy to install, great instructions . if you feel it will help you,go for it. i dealt with a old machine. without for 30 years yet after getting a new car with a heated steering wheel, i was all for a new machine with them . better to install now then having to install them later while possibly being in a on heated area with bare hands
latter if you don't need them, don't turn them on.
10953 is offline
post #6 of 11 Old 01-18-2018, 12:09 PM
i am curious if you made these work? I bought the kit which has all 2 prong plugs. My 2460 has a 4 prong plug. I called tech support and they told me that this model does not support them?
I will look into retrofitting myself but curious if i got bad info from tech support?
cmc76 is offline
post #7 of 11 Old 01-18-2018, 12:40 PM
Thanks (Given): 28
Likes (Given): 157
If you have the red wire, you should be good to go. Check your voltage with the warmers turned on.
Troy-Bilt Storm Tracker 2890
post #8 of 11 Old 01-18-2018, 01:59 PM Thread Starter
Likes (Given): 14
Likes (Received): 7
I have not tried yet, the blower is too new for me to mess with this year, so I was planning for a spring modification. Let me know how you make out.
post #9 of 11 Old 01-18-2018, 03:45 PM
I will have to take a look at what wires are there. I know it looked like 2 were used. Unsure of the color. But i have to assume i could steal some power from the headlights. Especially considering i will likely swap out for LED with a lower draw.
cmc76 is offline
post #10 of 11 Old 01-18-2018, 03:57 PM
Likes (Received): 302
Just enough.
