Thoughts on Blower 2007 Troy bilt Snow King 30" 318cc 11HP 2 stage - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 12-10-2017, 11:18 PM Thread Starter
Likes (Given): 7
Thoughts on this snowblower and Troy Built in general? This is for a friend with a fairly large driveway. I have no experience with Troy Builts are they quality machines? I can't seem to find much info on this model. Is it a Tecumseh engine?
https://www.kijiji.ca/v-snowblower/b...utm_source=sms
ICECOLDBEER is offline
post #2 of 8 Old 12-10-2017, 11:29 PM
overpriced piece of mtd junk. look for an ariens honda or toro
post #3 of 8 Old 12-10-2017, 11:35 PM Thread Starter
Likes (Given): 7
This is kind of my opinion as well but it seems half decent. Big engine and all. Are these machines prone to any known issues?
post #4 of 8 Old 12-11-2017, 06:03 AM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 59
Likes (Given): 131
Likes (Received): 219
I have the Troy-Bilt 2410 . . . mid-range machine. I got mine for $499, so it was a good budget machine.
The auger blades are lightweight, and I thought that they would easily bend, but so far they have not. The impeller design is poor and you will want/need the impeller modification.
The drive and impeller engaging mechanisms are cables rather than hard linkages, so they can have a lower life span.
I think Troy-Bilt (MTD) is out of their league making a 30" machine.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #5 of 8 Old 12-11-2017, 08:28 AM
Likes (Received): 66
I've got a similar 28" 2007 MTD and it has handled about 12' of snow now for each of the past 10 years; but mine doesn't look as pretty as this one.
They failed to mention that this has "Heated Grips". The Single Lever "Joystick" is nice; but it does frost up occasionally (the hardest part has been understanding how it works!). Otherwise, a few belts, inner tubes, a friction wheel, and a couple cleanings of the Idle Restrictor Screw, and annual oil changes is about all it has really needed. I don't see why it won't last another 10 years or more. Keep it dry; keep it clean. I'd buy it again.
This 30" was priced at about $1050 in 2007. If the pictures represent its true condition close-up, it must still be worth at least half of that.
Vermont007 is offline
post #6 of 8 Old 12-11-2017, 10:05 AM
Thanks (Given): 28
Likes (Given): 157
Likes (Received): 39
Nothing wrong with Troy-Bilts! Just maintain them and they are as good as any other brand.
Troy-Bilt Storm Tracker 2890
jonnied12 is offline
post #7 of 8 Old 12-23-2017, 08:32 PM
Anyone have a flex that they have retrofit with a starter or anything else?
Sent from my XT1585 using Tapatalk
zak2883 is offline
post #8 of 8 Old 12-23-2017, 09:00 PM
Thanks (Received): 385
Likes (Given): 177
Likes (Received): 892
Not true..
It is not correct that all brands are of equal quality, this is well known and often discussed here.
sscotsman is offline
