Troy Bilt Vortex 31BH5DR7563 revs up when taken off choke (brand new) - Snowblower Forum : Snow Blower Forums
post #1 of 30 Old 12-24-2017, 08:19 PM Thread Starter
Very strange problem I got here...
Bought 2 weeks ago, followed the instructions to the letter, had an oil change.
2 days ago it was running perfectly well, I start it today and its as if someone put nitro in there.
One, I barely pulled on the starting cord and honestly it almost scared me, like something explosive was in there and the engine started revving up to its maximum within half a second, I think it even burned the light.
Fresh gas (same tank), brand new machine, worked two days ago, now it wants to explode.
When I start it in full choke position it will idle somewhat normally... as soon as I touch the choke button (and I mean barely touch it) the engine revs up like there is no tomorrow.
Thats right, I'm not even switching it off full choke, merely pressing in the direction sends the engine in highest revs possible.
What can it be ?
Thanks in advance and merry christmas, an answer would be the best gift I could receive because I'm stucking in my driveway with 50 cm of heavy snow :/
Ahunata is offline
post #2 of 30 Old 12-24-2017, 08:54 PM
Thanks (Given): 228
Thanks (Received): 194
Likes (Given): 2018
Likes (Received): 511
Welcome to SBF and Merry Christmas!
I assume you don't have access to a tachometer nor able to gauge what ~ 3600 RPMs sounds like.
Exceeding the recommended RPM could destroy the engine.
Asking you to upload a video of it puts the engine at risk.
Overrevving could be caused by a stuck carb throttle linkage, an obstruction or a busted internal governor (assuming you didn't monkey with the linkage, governor spring tension, etc.)
Does the engine have a throttle control where you can run it at reduced-throttle?
('87 Toro 38150 826)
classiccat is online now
post #3 of 30 Old 12-24-2017, 09:06 PM Thread Starter
No, no access to RPM meter, but I'd assume around 3-4000 RPM, I didn't let it run for more than a few seconds at that rate it is scary and the whole thing vibrates.
The governor could be stucked even on a brand new machine ?
I didn't open it or nothing it is brand new and was working perfectly two days ago :/
What makes me think it could be a not well oiled throtle linkage is that there is absolutely no effect when I move the throtle, it only stops when I reach full stop !
The only other thing affecting the RPM is when I touch the choke button, as soon as I touch it it starts revving up to full speed.
Ahunata is offline
post #4 of 30 Old 12-24-2017, 09:09 PM Thread Starter
@classiccat
There also used to be quite a marked difference between the levels on the choke button.
Now it simply goes crazy when I touch it...
But what puzzles me most, is how easy it started... it really felt like nitro, the engine didn't even do one rev and it was already firing up like it was warm ! I could have pulled the crank with two fingers it would have started.
I actually see the mechanism that moves when I move the throttle lever, it looks brand new, there is no water or corrosion in there.
Ahunata is offline
post #5 of 30 Old 12-24-2017, 09:46 PM
Thanks (Given): 228
Likes (Given): 2018
Originally Posted by Ahunata View Post
@classiccat
I have to confess, I'm trying to gauge your experience with outdoor power equipment vs a malfunctioning machine.
It sounds like it MIGHT be running properly, you're simply surprised with how quickly it popped to life when starting & it's running loud/rough b/c it's partially choked (running too rich (due to partial choke) causing it to shake).
Try starting at half-throttle (this usually disengages the governor) and get it off the choke without it sounding like it's running away.
Sidenote: I usually avoid starting an engine at full throttle.
It should smooth-out as you open the choke...at that point gradually increase the throttle.
At any point it sounds like it's running away on you, shut it off.
try to record a video and post it.
Thanks Ahunata thanked for this post
Likes Ahunata liked this post
post #6 of 30 Old 12-24-2017, 10:03 PM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 177
Now that I see this I agree with that diagnosis.
leonz is offline
post #7 of 30 Old 12-25-2017, 12:32 AM Thread Starter
Sounds good I will try it...
One question however, previously to any of this happening when I pulled the throttle to the right the engine would slowly fade off. Now there is no difference until I hit the stop point.
so its either running a little too rich while fully choked, and when I move the throttle to attempt to lower the idle nothing happens until I hit stop.
Sorry if I'm repeating myself just want to make sure nothing gets lost in translation
Ahunata is offline
post #8 of 30 Old 12-25-2017, 12:40 AM Thread Starter
I just want to make sure I don't break it... it sounds awfully high rpm...
can't take it back to the store unless I shovel 20 inches of snow on a good 50 feet... christmas will have to wait...
*sigh*
I will try to start it as previously said at half throttle and see if the governor kicks in tomorrow morning, thanks for the replies much appreciated !
Ahunata is offline
post #9 of 30 Old 12-25-2017, 09:08 AM
Likes (Received): 66
Every engine that I have has its own personality, and likes to be treated as an individual; but to refresh my memory for this Thread, I just re-read the instructions for the Tecumseh Engine that powers my 2007 Snowblower . . . . something that I don't recall doing since it was new !
The Instructions, which I've been following religiously (or habitually) for over 10 years, say to move Speed Control (that seems to mean Throttle) all the way to FAST (which would indicate Full) and to position the Choke at FULL in preparation for Starting.
Then, upon being started (and paraphrasing Tecumseh's Instructions) I immediately begin being reducing the Engine Speed 25% or 50% and I set the Choke to about or less while I let the engine warm up without missing, for a minute or so, and when warmed up, I eliminate the Choke altogether and return the Speed (Throttle) to FULL while I put the machine to work.
Choking any engine should be considered ONLY as an aide in getting it started; not as a setting while it's being used.
I recognize that Tecumseh is now out of business; but their instructions still work for me.
Vermont007 is offline
post #10 of 30 Old 12-25-2017, 10:38 AM
Thanks (Given): 28
Likes (Given): 157
Likes (Received): 39
It sounds as if your throttle linkage may be disconnected in there somewhere. Get a good flashlight and operate the throttle lever without the engine running to see what moves or what doesn't move. It is also possible a governor control spring may have become disconnected.
Here is the engine repair manual that may help you out.
http://www.google.com/url?sa=t&rct=j...X3Ev3zKHW3bNxJ
See Chapter 3 and 4.
Troy-Bilt Storm Tracker 2890
jonnied12 is offline
