Troy Bilt Chute Diverter Stuck Fully Open - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 12-30-2017, 12:21 PM Thread Starter
Hello,
The chute diverter on my Troy Bilt 24" snowblower won't move up and down - when I try to drop it down it remains stuck in the fully open position. This has just started happening - note that it has been in the minus teens here for about a week! Looks like two cables run to it from the chute control
lever.
Martin is offline
post #2 of 4 Old 12-31-2017, 09:20 AM
Thanks (Given): 28
Likes (Given): 157
Likes (Received): 39
Loosen the bolts on the sides where it pivots and spray some silicone or Teflon all over everything. Heat the cables up with a hair dryer to make sure they are not frozen. Lube them and all of the control parts with the silicone or Teflon spray.
Troy-Bilt Storm Tracker 2890
jonnied12 is offline
post #3 of 4 Old 12-31-2017, 10:10 AM
Clutch Cargo's Avatar
Thanks (Given): 80
Thanks (Received): 35
Likes (Given): 96
Likes (Received): 94
If you know anyone who works on motorcycles, they may have a can of cable lube. This stuff works great.
2015 Ariens Deluxe 28
Previous Machines:
1995 Yard-White-Bilt 8/26 Frankenblower
1980 Toro 826
1981 Toro 3521
Clutch Cargo is offline
post #4 of 4 Old 12-31-2017, 11:20 AM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 221
Squirt antifreeze into the cable ends where the cable goes into the sheathing. Will never freeze. Cheap ,easy, and effective.
russ01915 is offline
