Storm 2410 oil change question - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 01-13-2018, 12:25 PM Thread Starter
Anyone know the approximate amount of oil (in terms of ounces) that Troybilt 2410 takes in
steveyal is offline
post #2 of 6 Old 01-13-2018, 12:39 PM
Thanks (Given): 28
Likes (Given): 157
Likes (Received): 39
Oil Recommendations
Before starting engine, fill with motor oil, capacity is 600
ml/20 oz.
Refer to the viscosity chart (Figure 3-1) for oil
recommendations. Do not over-fill. Use a 4-stroke, or an
equivalent high detergent, premium quality motor oil certified to
meet or exceed U.S. automobile manufacturer’s requirements for
service classification of a minimum level SJ (higher letter ratings
are acceptable such as SL and SM grades).
Motor oil will display this designation on the container.
Link to owners manual:
2-Stage Snow Thrower | The Storm 2410 Snow Thrower from Troy-Bilt
Troy-Bilt Storm Tracker 2890
jonnied12 is offline
post #3 of 6 Old 01-13-2018, 01:23 PM Thread Starter
Thank you Sir
steveyal is offline
post #4 of 6 Old 01-13-2018, 02:23 PM
Likes (Received): 13
0w30 synthetic is easier to pull start. Doesn"t thicken in exreme cold. Brand doesn't matter buy the cheapest.
coastie56 is offline
post #5 of 6 Old 01-13-2018, 02:52 PM
Print out the owners manual if you get a chance, lots of info under maintenance that if performed can save you grief. Ex, lube the hex shaft, etc.98% of folks never do it end up repairing there machine and still don't know to do it or why the speeds work funny...
Likes jonnied12 liked this post
post #6 of 6 Old 01-14-2018, 12:33 AM Thread Starter
Thanks guys
steveyal is offline
