Storm 2860 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 11-14-2018, 05:03 PM Thread Starter
Storm 2860
New here and I just got to use my new storm 2860 for the first time today, and I already have a question. The machine work and ran great but when I went to back it up into the shed it seemed the reverse setting 1 wasn't working quite right. Reverse setting 2 worked fine, but it just seemed 1 was way to slow. Like it was barely moving. Anyone else ever have this issue? When I get a chance I will test it out some more and see if it still seems off.
Cold47 is offline
post #2 of 6 Old 11-14-2018, 05:33 PM
Thanks (Given): 78
Thanks (Received): 161
Likes (Given): 401
Likes (Received): 641
sounds like it needs some adjustment.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 6 Old 11-14-2018, 05:46 PM Thread Starter
I hate to think my new snowblower needs adjustments already 😠. Reverse 1 is between forward 1 and reverse 2. All other speed settings work fine so why would that 1 setting be off? I will have to try it out again tomorrow.
Cold47 is offline
post #4 of 6 Old 11-14-2018, 05:51 PM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 65
Usually the reverse speeds are pretty slow. They probably do this intentionally to prevent injury.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #5 of 6 Old 11-14-2018, 06:41 PM
Thanks (Received): 208
Likes (Received): 764
don't worry..you can tip the machine up, pull the pan and adjust the speeds to any thing you are happy with.....I'd just leave it be.
cranman is offline
post #6 of 6 Old 11-14-2018, 08:13 PM
Zavie's Avatar
Thanks (Given): 71
Thanks (Received): 117
Likes (Given): 562
Likes (Received): 258
Yes, this exactly. If you look at pages 16-17 in your manual it shows how adjustments are possible. On my Simplicily I thought 1st was a bit fast so I made an easy adjustment to suit the way I wanted my machine to work.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
