2410 predator Swap pulley info need help snowing :( - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-26-2018, 09:57 AM Thread Starter
Exclamation 2410 predator Swap pulley info need help snowing :(
Trying to Swap my old 2410 that had the 5.5hp techumse. i bought a Predator 212 in hopes it would be a easy swap. Just got my 3/4-7/8 sleeve in hoping that i could use the stock pulleys with no luck. Does anyone have a link to where they found 3/4 inch pulleys and what sizes i need for the drive and auger using stock belt sizing?
Kevin Tourneur is offline
post #2 of 5 Old 11-26-2018, 01:26 PM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 59
Likes (Given): 131
Likes (Received): 219
I got some at Tractor Supply for my 2410 retro-fit. Just measure the diameters of the pulleys needed and source at tractor supply, or Zoro.com, etc. Lots of places have pulleys.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #3 of 5 Old 11-26-2018, 03:42 PM
Thanks (Received): 208
Likes (Received): 764
What size is your original shaft? I've gone with the original pulleys from 3/4 shaft Tecumsehs, and I've had good luck sleeving up the 3/4 shaft engines to 1" with the sleeve....I never saw a 7/8 sleeve ,but if it exists, why can't you use it?
cranman is offline
post #4 of 5 Old 11-26-2018, 05:33 PM Thread Starter
Original shaft size is 7/8ths the stock pullies are not aligning correctly and do not have set screws. Also the pullies have a key and barely engage the key way on the 3/4 shaft with the sleeve on there.
post #5 of 5 Old 11-26-2018, 11:18 PM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 65
PM sent
Ariens ST11528LE
Honda HS720
Motor City is offline
