8526 Storm wheel spacers - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-07-2018, 12:06 PM Thread Starter
Exclamation 8526 Storm wheel spacers
I removed the wheels to replace the tires, but when I went to reinstall the wheels they wouldn't push onto the axle far enough to pin them. Is there some spring load that the spacers have to push against? I didn't want to force anything before asking
Jim Krug is offline
post #2 of 3 Old 12-07-2018, 12:12 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
Both wheels? or only on one side?
If one side, remove the wheel that fits, there's a round clip, some type of lock ring, using a screwdriver, pry it moving it outward 1/8" -1/4" then push the axle in towards the side that doesn't fit.
JLawrence08648 is offline
post #3 of 3 Old 12-07-2018, 04:00 PM
Thanks (Given): 573
Thanks (Received): 747
Likes (Given): 4240
Likes (Received): 1665
to SBF Jim
Please don't post the same question in multiple forums. It just get confusing.
Likes VirginIASnow liked this post
