Tracker 2690 XP Rehab - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 12-15-2018, 12:15 AM Thread Starter
tabora's Avatar
Thanks (Given): 43
Thanks (Received): 221
Likes (Given): 131
Likes (Received): 422
I just purchased a lightly used Troy-Bilt Tracker 2690 XP for my son for only $400, since the seller was not able to get it to start. I changed the oil, cleaned the spark plug on my grinder's wire wheel, filled the tank with fresh gas and then drained a few tablespoons of gas/water from the carburetor bowl. Total of about 18 minutes effort. It started right up and I ran it for 1/2 hour to make sure it was happy.
I have a new scraper bar, Arnold roller skids, RacingPowerSports hour meter/tach, leading edge guard and Husqvarna drift cutters to install on it this weekend and then will present it to my son, a new home-owner.
A very happy experience!
ID:	149969   Click image for larger version
ID:	149971   Click image for larger version
ID:	149973   Click image for larger version
ID:	149975   Click image for larger version
Name:	Arnold Rolling Skid Shoes 490-241-0038.png
tabora is online now
Likes Kiss4aFrog, PaulMys liked this post
post #2 of 15 Old 12-15-2018, 09:22 AM
Likes (Given): 38
Likes (Received): 244
You're a good Dad. Great job, and great deal.
RIT333 is online now
post #3 of 15 Old 12-15-2018, 10:54 AM
Thanks (Given): 169
Thanks (Received): 304
Likes (Given): 421
Likes (Received): 1012
Good job. Good Dad.
Pretty clean machine, too.
post #4 of 15 Old 12-15-2018, 02:08 PM
Thanks (Given): 571
Thanks (Received): 742
Likes (Given): 4214
Likes (Received): 1638
Once you present it to him you'll need to sign him up so if he has any questions when you're not available he'll always have us.
Nice first blower.
post #5 of 15 Old 12-15-2018, 05:28 PM Thread Starter
tabora's Avatar
Thanks (Given): 43
Likes (Given): 131
Well, now I'm stumped... It appears that the chute control rod that runs the chute rotation (this blower has a 4-way electric joystick to control the chute) is too short. If it's seated correctly at the motor end, it is 3/4" too short to reach into the socket where the clip goes through both socket and rod to secure it. If it's secured at the chute/socket end, it's too short to reach the motor and engage the drive. Thoughts, anyone? There does not appear to be an adjustment for this.
post #6 of 15 Old 12-16-2018, 09:51 PM Thread Starter
tabora's Avatar
Thanks (Given): 43
Likes (Given): 131
So, after looking at things thoroughly, and removing the entire chute control assembly and chute motor housing, there is really no adjustment to correct the clearly too short control rod issue. I ended up drilling a new hole in the very end of the control unit socket, which allowed the other end of the control rod to seat properly in the collar on the chute motor housing.
Name:	Chute Control Mod.jpg
post #7 of 15 Old 12-16-2018, 10:03 PM
Thanks (Given): 58
Thanks (Received): 70
Likes (Given): 238
Likes (Received): 156
Good job fixing the short control rod. Maybe it was bent improperly to begin with? Either way I'm sure your son will enjoy it.
Paul
paulm12 is online now
post #8 of 15 Old 12-16-2018, 10:41 PM
Likes (Given): 38
Short rod - really makes you wonder if they ever use these things in the factory before they sell them !
post #9 of 15 Old 12-16-2018, 11:44 PM
Thanks (Given): 571
Likes (Given): 4214
Maybe the handle bars were bent a little opening up the distance between the motor and the chute ?? I used one of those Troys once and the pin you pull just in case the motor stops. That way you can manually crank it until you repair or replace the motor.
post #10 of 15 Old 12-17-2018, 12:27 PM
drmerdp's Avatar
Thanks (Received): 144
Likes (Given): 24
Likes (Received): 301
Thatís a good call. Maybe loosen the 4 bolts holding the handles to the tractor and see if you can push up on the handles and retighten.
On those MTDs I always drill out the lower hole beneath the existing plastic wing nuts and add a bolt. Makes the machine feel way more Sturdy.
drmerdp is offline
