Real Clean Gardenway - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 12-29-2018, 10:20 PM Thread Starter
Likes (Received): 40
https://rochester.craigslist.org/grd...782531000.html
Not sure the vintage?
TY
Red
bigredmf is offline
post #2 of 8 Old 12-30-2018, 04:00 AM
Dusty's Avatar
Likes (Received): 12
You know what's crazy. That is not an actual Gardenway. That is definitely after MTD bought out the brand and then exploited it briefly. Wow MTD uses yet another brand name. That's now 31 I count.
Dusty is offline
post #3 of 8 Old 12-30-2018, 12:17 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 146
Likes (Received): 286
Yes exact MTD parts, Had a Yard Machines that was the exact clone right down to the headlight.
Dauntae is online now
post #4 of 8 Old 12-30-2018, 05:53 PM
Thanks (Received): 208
Likes (Received): 764
You know...the more I work on MTDs the more respect I have for them......cheap and they work. EASY to work on too! At least the ones with Tecumsehs......
cranman is offline
post #5 of 8 Old 12-30-2018, 06:10 PM Thread Starter
Was wondering if it was from the heyday of Garden Way. I believe some were made in NY?
bigredmf is offline
post #6 of 8 Old 01-20-2019, 01:00 PM
Thanks (Received): 7
Likes (Received): 19
Hello I come across a lot of equipment with well known names only to find out GardenWay were involved in the production.
New Jersey, Toro 8/24, Ariens 5/22, small engine repairs
Bluejoe is offline
post #7 of 8 Old 01-20-2019, 01:07 PM
Thanks (Given): 13
Likes (Given): 146
When Gardenway was Gardenway before MTD purchased them they made some great machines, They also owned Troy Bilt when they made good machines. I have a Gardenway Tiller and when I did a search on the model the numbers are the same as the Troy Bilt Horse and parts are interchangeable between the two. MTD cheapened the brand then did away with the name.
post #8 of 8 Old 01-20-2019, 01:32 PM
Thanks (Given): 95
Thanks (Received): 193
Likes (Given): 73
Likes (Received): 444
GardenWay use to advertise on tv. I could be wrong but I thought TroyBilt bought GardenWay then soon after MTD bought TroyBilt absorbing GardenWay, then doing away with it. I have for sale a 30" GardenWay walk behind mower a neighbor gave me. An inexpensive cheap homeowners mower with a wide cut, a pseudo landscapers mower, without a ZERO turning radius!
JLawrence08648 is offline
