How do I park a Storm 2410 on a hill? - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-06-2019, 11:14 PM Thread Starter
I just picked up a Storm 2410 and tried it on my dry sloping driveway today. How do I stop and park it on the slope? Per the manual, when the drive control is adjusted properly, it free-wheels with the drive control released. How do I stop and park it to catch my breath, clear a clog, remove a fallen branch, etc.
If I'm headed downhill the snow will probably keep it from rolling--but what about when I'm headed uphill?
It seems like I have to stop the engine and strap the drive control grip down to engage the transmission--but I would need an extra hand on a long arm to do that while holding onto the handles.
Am I missing something?
ikanode is offline
post #2 of 5 Old 01-06-2019, 11:21 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
What about turning it sideways?
Turn the auger off, turn down the idle, put it in 1st gear, let the snow stop the snowblower from moving forward.
post #3 of 5 Old 01-07-2019, 06:48 AM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 146
Likes (Received): 289
Or just angle it so it rolls back into the remaining snow.
Dauntae is online now
post #4 of 5 Old 01-07-2019, 01:36 PM
Grunt's Avatar
Thanks (Given): 268
Thanks (Received): 326
Likes (Given): 3238
Likes (Received): 660
Welcome to SBF ikanode. You could get a rubber o-ring or two from the hardware store that fits snuggly over rear part of the hand grip then depress the drive lever and slide the o-ring over it to keep it depressed. For clearing a clog or debris, the motor MUST be turned off for safety anyway.
post #5 of 5 Old 01-07-2019, 05:34 PM Thread Starter
Thanks for the suggestions. I was surprised yesterday in gear one, when I released the drive lever and the snowblower sped up. I may get to use it this weekend. There's a chance of snow where I live in North Carolina on Saturday. Current predictions are anything from intermittent snow & rain showers to 8" of heavy snow.
I have 1000' feet of narrow asphalt--most sloping. There's a 4' deep ditch on one side and a ravine on the other. Turning the snowblower sideways may work once I get more comfortable with controlling it. If we get significant snow, the unplowed snow should act as a brake. A friend suggested that I get a small rubber chock--that will work when I'm headed uphill since I can easily reach behind a tire. Maybe I can learn to drop it over the front of a tire. I'll try the engine-off, O-ring trick.
Some combination of the above is bound to work.
Thanks all,
ikanode is offline
