need a pulley adapter - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 03-19-2019, 09:37 PM Thread Starter
I have a troy bilt 31am6cp4711 snowblower with a broken pulley adapter.
It's this large adapter that basically locks the pulley to the axle for the auger.
I see several online that look suspiciously like it. Are they all the same?
It not, where is a good place to look up that part nr ?
I also have a craftsman and the whole auger/shroud section look VERY similar.
thanks !
geekwithoutacause is offline
post #2 of 3 Old 03-19-2019, 10:32 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
Your Troy Bilt and Craftsman are similar because they are both built by MTD.
PartsTree.com, Jack's Small Engines
post #3 of 3 Old 03-19-2019, 11:18 PM Thread Starter
Awesome, I found the part on Jack's small engines.
Thank you !
Similar Threads
Ariens 28 deluxe 2015 model traction disc drive belt Lottstodo Ariens Snowblowers 21 02-16-2018 06:30 PM
Single Stage - How to Remove Auger Pulley unknown1 Craftsman Snowblowers 1 08-17-2017 10:58 PM
Variable (adjustable) pulley JLawrence08648 Snowblower Repairs and Maintenance Forum 0 02-19-2017 08:38 PM
Craftsman 22inch, groove in idler pulley warrior1978 Snowblower Repairs and Maintenance Forum 9 02-28-2015 08:31 AM
Manual pull starter on Craftsman snowblower Grayte Snowblower Repairs and Maintenance Forum 17 01-12-2011 11:23 PM
