tb 2690xp broken auger axle - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 02-03-2013, 01:40 PM Thread Starter
just wondering how to replace auger axle must have broke when i picked up a big rock thanks
mick l is offline
post #2 of 15 Old 02-03-2013, 03:03 PM
Which part are you talking about. The one that goes from the engine, Impeller into the gearbox or the one that goes between the gearbox that the Augers actually attach to using sheerbolts. Also Include a make and model for your snowblower to help you find the right parts.
3 Ariens 522 Single Stage
Toro 3521 Repowered with a 6.5hp
Craftsman 521 (selling)
other toys
Troybuilt Horse 70s or 80s model
Troybuilt Econo-horse
John Deere Jx75
John Deere Js46
John Deere 111
and a few other parts machines.
Colored Eggs is offline
post #3 of 15 Old 02-03-2013, 03:06 PM
td5771's Avatar
Likes (Received): 57
we could use some more information to help.
model number? should start with 31aaxxxx or something like it
on a sticker or plate on the tractor portion of the
snow blower
where did it break? at one end by the auger housing? by the center by the auger gear
case?
pictures would be a tremendous help
td5771 is offline
post #4 of 15 Old 02-03-2013, 03:09 PM Thread Starter
the axle shaft that the 4 sheer pins attach the 4 augers to 26" long my blower is a mod 31bm73q3711 ser# 1f290z40112 thanks for inquring mick
mick l is offline
post #5 of 15 Old 02-03-2013, 03:19 PM Thread Starter
standing in front of it broke between the two right auger blades thanks
mick l is offline
post #6 of 15 Old 02-03-2013, 03:20 PM Thread Starter
havnt torn apart but looks like broke on a sheer pin hole
mick l is offline
post #7 of 15 Old 02-03-2013, 03:24 PM
Here is a breakdown for your machine. https://www.partstree.com/parts/?lc=...n=769070370008
I used the model number to bring it up. It looks like you need a 53.00 shaft. Luckly it looks like its something that is still made.. Ok question 2.
Did you damage your auger gearbox. That is a very important part and if you hit a big rock you may have damaged that as well. Send us some pictures to help us figure out what can be done.
other toys
John Deere Jx75
John Deere Js46
John Deere 111
post #8 of 15 Old 02-03-2013, 03:36 PM Thread Starter
gear box is ok i dint know there was a problem until i put away still blowing pretty good but not like when all augers are spinning, is it hard to remove and install new part
mick l is offline
post #9 of 15 Old 02-03-2013, 03:43 PM
I'm still new to this but I needed to replace a shaft on a Craftsman (older model) and the whole gearbox needs to be taken apart to replace the shaft. I have never worked on one of the newer models like yours but I would guess that it would be similar.
other toys
John Deere Jx75
John Deere Js46
John Deere 111
post #10 of 15 Old 02-03-2013, 03:51 PM Thread Starter
thanks man, mick
mick l is offline
