auger belt vibrating/flapping - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 11-24-2019, 06:54 PM Thread Starter
Hello, I have a troy bilt 2410 snow blower. Model 31AS62N2711. Bought used.
The issue is - when the engine is idling and the auger is disengaged - the belt vibrates/flapping really bad on the opposite side of the idler pulley. I adjusted the belt tension to various tensions - too loose, too tight, and just right - but it vibrates/flaps all the time. I also moved the idler pulley to a tighter setting but it did not work.
The belt is new part #754-04050A. It says that this belt replaces (or is the same as) the proper number which is #954-04050A - but I am not sure. It seems the belt is too long...??
Questions - Other than the belt, what can cause this? The new belt is a V-belt - Should it be a clogged belt?
tjoyce81 is offline
post #2 of 27 Old 11-24-2019, 07:00 PM
oneacer's Avatar
Thanks (Received): 122
Likes (Received): 430
Does that machine not have belt guides, as all my machines have?
I use the Gates Power Rated Green .. ?
oneacer is online now
post #3 of 27 Old 11-24-2019, 07:26 PM Thread Starter
No. It uses the head of a bolt (as a damper?) - and a bracket attached to a spring to kinda guide the belt in the pulley. The only guide for the belt is the actual pulley's V.
A belt guide where my belt is vibrating seems to make sense - but there is none.
tjoyce81 is offline
post #4 of 27 Old 11-24-2019, 07:33 PM
oneacer's Avatar
I am wondering if someone removed it, and never put it back. Does the schematic show one?
post #5 of 27 Old 11-24-2019, 07:47 PM Thread Starter
Where would the guide be?
This is my first snowblower - but I am pretty good at mechanical stuff. Seems someone did remove something...Just not sure..
tjoyce81 is offline
post #6 of 27 Old 11-24-2019, 08:46 PM
Grunt's Avatar
Thanks (Given): 259
Thanks (Received): 315
Likes (Given): 3130
Likes (Received): 618
Welcome to SBF tjoyce81. I don't see any auger belt guide in the service manual. If the belt is new and has no nicks or cuts, you could possibly have an auger pulley that is slightly bent and catching the belt causing the flapping.
Service manual for MTD machines-
http://service.mtdproducts.com/Train...owthrowers.pdf
Thanks tjoyce81 thanked for this post
post #7 of 27 Old 11-25-2019, 02:19 AM Thread Starter
Thanks for the welcome. I will check the auger pulley, but this only happens when the auger is dis-engaged. When engaged it runs perfect - smooth and strong... I slid the belt off the auger crank pulley and ran the engine. The auger drive pulley (on the crank shaft) looks good and runs just as smooth as the drive crank pulley.
A miss-alignment makes sense so will check closely...
I do see a belt guard in the service manual - thanks a lot for that! On page 7, figure 2.2. There is not one on my machine - but I did buy it used and it could have been removed.
Wondering on the belt. Does anyone know the difference in a mtd-954-04050a and a mtd 754-04050a? if any? Is there a slightly shorter belt for these machines? I see a mtd-954-04050 (no letter 'a')...?
tjoyce81 is offline
post #8 of 27 Old 11-25-2019, 02:23 AM
ST1100A's Avatar
Thanks (Given): 131
Thanks (Received): 115
Likes (Given): 243
Likes (Received): 193
That's just an updated number, its the same belt. MTD changed the numbering system from the "7" prefix part number to the "9".
ST1100A is offline
post #9 of 27 Old 11-25-2019, 08:56 AM
Thanks (Given): 14
Thanks (Received): 38
Likes (Given): 279
Likes (Received): 73
954 is the new belt there is no difference , mtd dose this all the time old number 754 new number 954 ,
87powershiftx2 is offline
post #10 of 27 Old 11-25-2019, 09:15 AM
oneacer's Avatar
Maybe a belt guide was omitted in the design, and should have been one in place … ?
I believe all my blowers have some sort of belt guide setup, which prevents belt slack flap as well as keeping it from popping off.
