gear oil for a 1994 troy bilt 21" - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 07-16-2014, 07:49 AM Thread Starter
Hi all, new to this forum. I have a 1994 Troy Bilt model snow thrower two stage that I obtained. It is in showroom condition. I was doing preseason maintenance on it and want to drain and refill the gear oil. My question is it calls for 90W gear oil. I can't find it anywhere. Any ideas where or what is an acceptable substitute? Thanks.
PGRNPA is offline
post #2 of 5 Old 07-16-2014, 10:06 AM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 42
Any auto parts store. Get one with a multable grade, so it will flow better in the cold weather.
Sid
Sid is offline
post #3 of 5 Old 07-16-2014, 10:25 AM
Likes (Received): 1345
80-90 Weight non synthetic gear oil. you can use name brand or store brand either will work. I use Castrol myself, DRIVE HARD!!!!
post #4 of 5 Old 07-16-2014, 01:37 PM
make sure what you get is safe for brass and yellow metals
post #5 of 5 Old 07-18-2014, 01:10 PM
Thanks (Given): 572
Thanks (Received): 747
Likes (Given): 4237
Likes (Received): 1657
Welcome to the forum
They are recommending a GL4, NOT a GL5.
Or , , A GL-5 that specifically states that it "protects against heat and corrosion of brass and copper".
http://www.castrol.com/en_in/india/products/truck-and-bus/manual-transmission-fluids.html
