storm2410 engine swap - Snowblower Forum : Snow Blower Forums
post #1 of 56 Old 08-23-2014, 12:35 AM Thread Starter
Likes (Received): 9
I have a Storm2410 snowblower with a 179cc powermore engine. I'm looking to put on either the Predator 212cc or the LCT Stormforce 208cc. Has anyone mounted either of these engines to their machine?
storm2410 is offline
post #2 of 56 Old 08-23-2014, 06:53 AM
Many of us have put Predator engines on our blowers. Worst thing you will run into is having to enlarge the main jet in the carb to allow a little more gas in.
I don't remember hearing of anyone mounting an LCT, but Ariens has been using LCT engines and I don't recall any issues on those.
post #3 of 56 Old 08-23-2014, 10:48 PM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 65
I just picked up a older, but similar model, but with a blown Tecumseh. I think I'm going to reto-fit a Predator on it. From what I can figure out so far it doesn't look very hard to do.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #4 of 56 Old 08-23-2014, 10:54 PM
GustoGuy's Avatar
Thanks (Given): 47
Thanks (Received): 76
Likes (Received): 128
The 212cc will have more torque than the 179cc engine. There is no replacement for more displacement. My old MTD with the Predator 212cc throws snow farther and higher than my neighbors much newer 8 hp machine
GustoGuy is offline
post #5 of 56 Old 08-24-2014, 12:44 AM
Motor City's Avatar
GustoGuy,
Did yo have to use a different length belt when you did you conversion. And if so how did you figure out the right size? I am going to try and buy pulleys that are the same diameter as what was on my machine. But I anticipate that I will have to get different belt lengths.
Ariens ST11528LE
Honda HS720
post #6 of 56 Old 08-24-2014, 07:39 AM
GustoGuy's Avatar
Thanks (Given): 47
GustoGuy,
You can use the rope trick to estimate which size belt you will need. If the pto shaft of the new engine is the same as the old engine you can often use the stock belt.
GustoGuy is offline
post #7 of 56 Old 08-24-2014, 01:19 PM
Grunt's Avatar
Thanks (Given): 268
Thanks (Received): 325
Likes (Given): 3224
Likes (Received): 655
GustoGuy,
This may help to get the correct size belt. Just enter the measurement to the center of each shaft and pulley sizes. I'm not sure if using a 3/8" or 1/2" wide belt makes a difference.
V-Belt Length Calculator
post #8 of 56 Old 08-24-2014, 01:21 PM
Motor City's Avatar
Unfortunately, the Troy Bilt I have uses a wimpy 1/4 in belt for the drive. I think I can fit a 3/8 belt on the lower pulley. So I will be starting from scratch on mine. I may get away with the original auger belt, but I'll have to see.
Ariens ST11528LE
Honda HS720
post #9 of 56 Old 08-24-2014, 10:59 PM
Motor City's Avatar
Ordered my Pulley, tonight. I did some research and if the friction disc on my machine won't accommodate the 3/8 belt, I think i found another MTD part, friction disc that is for a 3/8 belt. Its a 1/4 wider in diameter. But I think that shouldn't matter much with a more powerful motor. The dis is only $34, with free shipping. So it's not a big expense. I am just going to wait until next weekend to see if Harbor Freight has a labor day special on the Predator's.
Ariens ST11528LE
Honda HS720
post #10 of 56 Old 08-25-2014, 12:49 AM
I don't think it is really necessary to go up in size on the drive pulley. With the reduction going through the drive system there isn't a lot of torque on it. Plus the machine is a blower and not a plow so all you should be moving with it is the weight of the machine.
