Common problems with the Chinese engines. - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 11-16-2014, 11:38 PM Thread Starter
Ok, I know you guys are sick of me asking all of these questions, but everything about my 2410 is new to me (Two-stage, Troy-Bilt, Chinese engine).
So far, according to Youtube videos and internet forums: bad/old gas= problems.
Someone told me that the Chinese engines are ultra-sensitive to gasoline quality. The instruction manual says not to run with gas older than 30 days old. Today I put Sta-bil and fresh gas in the gas can. I know this will avoid several problems associated with the Chinese engine's intolerance to old gas.
What other problems should I look for and how to prevent...with the except of maintenance?
Kind of bummed because Tecumseh and Briggs engine will run regardless of fuel or oil quality.
Fruggy is offline
post #2 of 18 Old 11-16-2014, 11:54 PM
"Kind of bummed because Tecumseh and Briggs engine will run regardless of fuel or oil quality."
that is not true for newer briggs, they will display the same symptoms as the clones(surging, hard starting, start and die,not starting at all) because all modern engines are jetted lean
post #3 of 18 Old 11-17-2014, 12:04 AM
GustoGuy's Avatar
Thanks (Given): 47
Thanks (Received): 76
Likes (Received): 128
I own 3 HF Predator engines and I never have never had any problems with fuel issues. I use non oxygenated gasoline for small engines. You can use either Stabil or Sea Foam to stabilize the gasoline.
GustoGuy is online now
post #4 of 18 Old 11-17-2014, 12:42 AM
I use cheap 87 octane and sometimes have it for over a year and it works fine for me. No stabilizers added either.
post #5 of 18 Old 11-17-2014, 01:16 AM
Stupid question: Can that lean condition be fixed? Is there an adjustment?
thanks
Oracle is offline
post #6 of 18 Old 11-17-2014, 01:37 AM
thanks
You can open the stock jets with torch tip files or micro drill bits (by hand). Gustoguy uses floss and some polishing compound. You can buy different size jets as well.
post #7 of 18 Old 11-17-2014, 02:21 PM
Likes (Received): 7
Buy ethanol free premium if it's available where you live, it's $3.59/a gallon 2 blocks from my house right now. If not available you can go the stabil route, I've always put 2oz of marvel mystery oil in my 5 gal gas can before I fill her up and have never had a small engine carb issue....it's a good clearer and adds some top cylinder lube....
2014 Honda 928WAS
Erie, PA
-Avg yearly snowfall 100.8" (256cm)
-2013-14 Snowiest major city in the USA with 138.4" (351.5cm)
KpaxFAQ is offline
Likes LET-UT liked this post
post #8 of 18 Old 11-17-2014, 02:54 PM
enigma-2's Avatar
Thanks (Received): 20
Likes (Received): 49
All modern engines are now being jetted lean. Federal requirements. Worst are the CARB states. (California, forget who the other four are). Carburetors in those states have really small orifices.
Ethanol gas is a reality everywhere. If you can buy gas without it where you live, do so. If not (not sold anywhere near me that I know of) you must use a conditioner such as StaBil Marine, StaBil Ethanol, or SeaFoam. You don't need much and it will protect your investment. The alcohol starts to separate form the gas in as little as thirty days. Then it will draw water to to itself (makes a gum) and if the alcohol content accumulates too much, can cause the engine to run so hot it can actually melt a piston or burn the valves (see this on weed trimmers).
BTW, I don't think it has anything to do with being built in China. Most are build by one or two huge manufacturers, and they build for companies all over the world. Just built to US specs is all. All current engines must meet US air standards. Global warming and all that. (Not looking for a war on this, just my opinion).
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
post #9 of 18 Old 11-17-2014, 03:46 PM
"If not (not sold anywhere near me that I know of) you must use a conditioner such as StaBil Marine, StaBil Ethanol, or SeaFoam."
you dont have to use stabilizers if you follow some basic rules, dont buy more gas than you can use in under 30 days(1 gallon is plenty for most people), dont let gasoline sit in power equipment that is going to be unused for 30 days or more, install a fuel shutoff and burn off the gas from the carb after each use, and buy the cheaper 87 octane gas because it will be fresher, most people will not pay the extra money for premium, so it will sit at the station longer and not be as fresh. i never use stabilizer and have no problems
post #10 of 18 Old 11-17-2014, 09:50 PM
94EG8's Avatar
Thanks (Received): 48
They're not, they're very similar to a Honda for the most part.
No, they wont. I never saw anything as picky about gas as a Tecumseh.
That said, ethanol can be a big problem in any small engine, avoid it if you can. Where I am premium gas doesn't have ethanol so I buy premium. Also, remember if you're in a similar situation that whatever the last person pumped is still in the hose, so your first gallon is whatever the last guy selected, ideally pump that that first bit into your car before filling the jerry can. If you have to buy ethanol dump some stabilizer in it when the gas is fresh. Remember, stabilizer wont fix gas that's already gone bad.
94EG8 is offline
