Troy Bilt 42010 (824) electrical issue - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-07-2015, 03:00 PM Thread Starter
I have an older model Troy Bilt 42010. I can't get the light to work. It worked at one time.
Seems the issue may be the alternator. But its' odd. right after starting, I had about 6 volts, then, after getting it up to full speed, I have zero.
Any suggestions?
joea is offline
post #2 of 5 Old 02-07-2015, 03:42 PM
Likes (Received): 42
Hi joea,
Welcome to the forum. Sounds like a loose connection that is most symptomatic when high vibration kicks in. The problem could be under the flywheel...a loose attaching screw that loses contact at higher rpms. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #3 of 5 Old 02-07-2015, 06:02 PM Thread Starter
Originally Posted by motorhead64 View Post
Hi joea,
That's something I would rather tackle when it's warmer. Unless what you are thinking of might come out and damage something. ?
joea is offline
post #4 of 5 Old 02-07-2015, 07:56 PM
Well, if a screw did back all the way out, it could possibly get chewed up by the flywheel..my guess is the flywheel would win. It would be about a 2 hour job if all goes well to check out if all is okay. Personally, if I needed the machine to clear snow, I would gamble until the weather warms up a bit to pull it apart. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
post #5 of 5 Old 02-07-2015, 08:42 PM Thread Starter
Yep. By the way. Should I need an alternator/stator, where would I get one?
All the new parts web sites I've looked on don't list them at all.
The one's I've seen on Ebay have 3 coils, say about 30 degrees of arc, while the parts breakdowns I've seen show many coils, forming a 360 degree circle.
I suppose it might be more clear once I actually open it up.
joea is offline
