What's your opinion on Troy-Bilt tracked 2890 ?? - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 08-27-2015, 07:34 PM Thread Starter
Likes (Received): 9
Can anyone give me their honest evaluation of the Troy Bilt 2890 tracked SB. I found some reviews that were rather unkind to the TB machines in general because they are "simply rebranded MTD junk" I am considering the 2890 because, while the Honda and Ariens machines get great reviews, they are 2x and nearly 3x the price. (and yes I understand the argument of get what you pay for comments) Thanks so much.
Drift-King is offline
post #2 of 21 Old 08-27-2015, 07:48 PM
Thanks (Given): 572
Thanks (Received): 743
Likes (Given): 4224
Likes (Received): 1643
For the money it's a good homeowner unit. They are built to get the job done and nothing more. It's something that you want to keep up with maintenance on as it's not as forgiving as some others that were overbuilt.
Keep it as dry as possible when not using it, up off the salt from the car's melting road slush if stored in the garage, lube it often and inspect moving parts for wear BEFORE they cause you a problem instead of after.
If you do that you should be good for many years.
I have an abused Troy 2410 that I was given broken that I fixed and it's been getting the job done quite well on an almost 400' gravel driveway since my rider died two years ago.
post #3 of 21 Old 08-28-2015, 12:43 AM Thread Starter
Likes (Received): 9
Thanks so much for your prompt reply. I believe you identified the key element as "maintenance". I suggest that many of the problems I read about on these posts may be the result of casual care. I will keep it on my "short" list.
post #4 of 21 Old 08-28-2015, 01:07 AM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
Albeit, I appreciate anyone being budget conscious, I would personally get behind any unit before I buy it. I know that the Honda, and Ariens are priced above the Troybilts, but there is a reason. And considering that we are well beyond the snow season, you have the opportunity to shop. And I recommend doing so.
post #5 of 21 Old 08-28-2015, 08:16 AM
i dont like them, i think that they are poorly built machines and are only built to get the hob done and nothing more. after about 10 years even well maintained ones start rusting away. There is a **** good reason why the the only mtd product you will find in my garage is an old mtd push blower, and even that kind of suck, has a 6 piece stamped steel inpeller which makes it weak compared to something like my 30 something year old giant vac 5hp model which has a cast iron fan
post #6 of 21 Old 08-28-2015, 08:43 AM
Thanks (Given): 169
Thanks (Received): 305
Likes (Given): 421
Likes (Received): 1012
I've said it before. Troy Bilt made excellent rototillers, some of the very best ever. Everything else is highly suspect. You asked and this is my opinion only. Personally I wouldn't own one. I'd be much better off buying a decent used Toro or Ariens.
Likes Kiss4aFrog, 43128, detdrbuzzard liked this post
post #7 of 21 Old 08-28-2015, 09:03 AM
Zavie's Avatar
Thanks (Given): 71
Thanks (Received): 117
Likes (Given): 562
Likes (Received): 258
I would look at the Ariens Deluxe 28. You could add tire chains and handwarmers and still not be at the Troy-Bilt price. Better yet look at the Ariens Deluxe 28 SHO.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is online now
post #8 of 21 Old 08-28-2015, 10:03 AM
Thanks (Given): 572
Likes (Given): 4224
I'd have to say I'd rather have an older used better built machine but I go through them, rebuild them, paint them and maintain them. There are folks who don't want to get their hands dirty rebuilding something, don't have the time, don't have the tools or just like the warranty. As an auto mechanic it was nice having a new car and not having to work on it. Anything other than a simple problem and the car went in.
The Troy still starts easily, blows snow like crazy and once I replaced all the broken and worn out stuff hasn't give me one problem.
post #9 of 21 Old 08-28-2015, 10:18 AM
HJames's Avatar
Likes (Received): 11
I also believe it's all about care and maintenance. I have a 1999 MTD Yard Machines that I had to repower because the original Tec threw a rod, the rest of the machine is in great shape and I expect to get another 10+ years from it. It is certainly not built like my 1968 Ariens but nothing is anymore. I think you'll do just fine with the Troybilt as long as you're the type of guy that takes care of your equipment.
HJames is offline
post #10 of 21 Old 08-28-2015, 11:10 AM
Likes (Received): 303
Never owned one, but have worked on and ran a couple neighbors and friends TB, one of which was an actual tracked model. The metal is thin all over and they are light weight, tend to ride up. They wobble when put into heavy snow. The impeller/auger assembly when removed can be picked up from ground to bench with one hand. The separate little augers are thin and deform easily within 2 years use. They use plastic bushings on some. They use a Powermore engine that is extremely lean from the factory and gets worse after first couple tanks of fuel. Getting to anything on the engine involves removing cosmetic plastic shrouding and several hard to get to screws/bolts. The chute elevation control freezes and sticks at the chute and can pop out of the plastic holes it's mounted to. That said, they do work when you either open the jet on the carb or run with some choke. My concern would be at it's price point you can get a new Ariens or Toro , dealer network for each, and heavier gauge metal. Around here, there's no resale value on TB's. IMO it's like buying a 4 cylinder Mustang and putting the GT/Shelby graphics and wheels on it. You can get a new Toro 724 for nearly half the price of the TB. If I was going to spend that much on a blower I'd be buying a used Honda or saving a few hundred on a new Ariens Deluxe.
Likes 43128 liked this post
