5024 Storm Grease - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 10-16-2011, 10:10 AM Thread Starter
5024 Storm Grease
On a 5024 Storm,what grease would you use in the auger gearbox?
I was thinking something along the lines of "White Lithium" because of the temperature.
ravenworks is offline
post #2 of 4 Old 01-04-2013, 04:39 AM
Oldphil's Avatar
The problem with any grease is the cold operating temps, consider an exotic differential oil. THe best by far is Redline Oil 58204 Heavy ShockProof Gear Oil - 1 quart yes it is expensive but for the amount used a quart provides many years of top offs on my two machines. First time fill ups usually take a half dozen squirts from a standard pump oil can, topping off can is not needed for a few years. My auger drive machine needs two or three squirts about every third year, it is a 1993 TB Snow King which except for a carb in 2010 has run flawlessly so far.
Pretty old marine engine tech, now in marine parts.
Oldphil is offline
post #3 of 4 Old 01-04-2013, 08:10 AM Thread Starter
I ended up using "Shell-Areo" grease as my main concern wast compatibility with the bronze surfaces.
post #4 of 4 Old 01-04-2013, 04:32 PM
Simplicity Solid 22's Avatar
What is your model number and serial number??
