Is YT624EJ a good choice? - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 02-02-2018, 11:41 PM Thread Starter
Hi everyone,
I’m new on the forum and I need some advice...
I’m think about buying a new YT624EJ after 6 years with my Ariens Deluxe 28.
The Main reasons I want to change for a YT624 :
- kickup up effect of wheels
- Hydrolic assist auger tilt is much more easy on the shoulders than having to push down the handles on wheels models
- Hydrostatic transmission
However, concerns about YT624 :
- Will it throw as far as the Deluxe 28?
- 35 tons/hour...
- Made in China...
- No streering ... but i don’t even use the crappy one on my 2013 Ariens
Snow removal area:
-25’x30’ asphalt steep driveway
-50’x 20’ backyard (wood patio i access via metal ramps + grass)
- 2x 30’x 4’ sideways
- 30’ driftcut along the street
-Lots of 180 deg turns
Snowfall : moderate to heavy /10% wet snow......... I live in eastern Quebec so we have a lot of snow
Should i consider a YS1028J or is it too bulky (375lbs) and overkill for my needs?
Thanks in advance for your advice!
Rick70 is online now
post #2 of 20 Old 02-02-2018, 11:50 PM
Likes (Given): 467
Likes (Received): 480
Make your own conclusions... on the YT624
We have a few forum members that own one and are very happy with them
Check this thread
https://www.snowblowerforum.com/forum...aha-yt624.html
post #3 of 20 Old 02-02-2018, 11:54 PM
Likes (Given): 467
Though because of the amount of snow you get you may want to consider a YS1028J
post #4 of 20 Old 02-03-2018, 03:13 AM
Lunta's Avatar
Likes (Given): 108
Likes (Received): 64
I've had a YT660 (metric version of the YT624) for about a month. Have run around 10 hours with it. Amazing machine, very pleased. I especially like the hydrostatic tranny. Being able to adjust on the go makes things stupidly easy.
On one section I need to clear, I have the same situation. To begin with I blew a border around it, and made my 180 turns on that. But then I worked out that it was not much slower to simply blow in a forwards direction, then reverse up and blow another line forwards, reverse up again, etc. This saved me having to move the exit shoot 180 left-right-left-right each time.
Turning with tracks is ok, not difficult, but I can imagine wheels would be easier. I plan all my routes to minimuse turns, even if that means that I travel over some areas twice. I find that just keeping moving makes the job quicker.
The machine feels well put together, robust and solid. Pricey yes, but every time I use it, I'm pleased I got this rather than the other option at the time (a wheeled friction wheel Ariens).
Lunta is offline
post #5 of 20 Old 02-03-2018, 06:03 AM
TJJ
TJJ's Avatar
Likes (Received): 8
I have a YT660EDJ, i.e. the Japanese build one (with made in China engine... )
Making 180 turns is easy now that ground has an ice layer, you soon learn the tecnique of doing it and it's then almost your second nature. Reverse speed is slow and so I usually much rather do 180 turns. But it wasn't easy at all to do 180s when there still was gravel or grass with only a light layer of snow.
Since the YS1028 also has solid axles, and with added weight it probably is much harder to turn on those conditions. YS1070T model has an electronic button for turning, but I'm not sure where that model is available. It's price over here is pretty high, 5990 euros, 1000 euros more than the basic YT1070 (YS1028J over there) model. You can also get a Honda 1332 with that 5990 sum...
Yamaha YT-660EDJ
TJJ is offline
post #6 of 20 Old 02-03-2018, 10:02 AM Thread Starter
Hi TJJ
Since Reverse speed seems way faster on Yt624 than on my Ariens, reverse/forward is a good tip to avoid 180 deg turns
Regarding steering, it’s only avalaible on Yt1332ED. Yamaha Canada only offer YT624EJ, YS1028J and Yt1332ED . I know that Hss724 has steering but paying +1000$ for a steering: no way!
post #7 of 20 Old 02-03-2018, 10:15 AM
Coby7's Avatar
Thanks (Received): 106
Likes (Given): 28
Likes (Received): 690
You can't go wrong with a YT624EJ, My driveway is 120 feet long, I do up and downs with 180 turns at each end no problem. Just keep moving and by the time you swung the machine around the chute has also swung around. I've had mine now for 4 problem free winters. Turn the key and blow snow!!!
We normally get a lot of snow here except for this winter where we seem to get an Alberta clipper followed by a warm noreaster with rain. Suppose to rain again tomorrow after this last 6'' storm. -19C this morning +2C tomorrow and +6C monday. Really screwed up weather.
Coby7 is offline
post #8 of 20 Old 02-03-2018, 01:24 PM
TJJ
TJJ's Avatar
Likes (Received): 8
Yes, I also use reversing for short (5 meter) distances. And hydrostatic makes changing forward/reserve very smooth and fast and you soon also learn to make small direction adjustments while using that lever. YT624/YT660 is actually quite nimble machine once you get the hang of it.
Yamaha YT-660EDJ
TJJ is offline
post #9 of 20 Old 02-03-2018, 03:29 PM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 172
The small 624 being lighter in weight will take more time to clear heavy snows.
The 1028 is heavier and has more horse power with four more inches of cutting width with V belt drive.
Thinking five or 10 years down the road if you invest in a 1028 you will have more usable
horsepower and torque. The 1028 has an electric clutch for the cross auger and impeller drive and a V belt.
There is a fellow on you tube that lives in Newfoundland that has posted several videos of his 1028 working
in his deep snows and it has no problems working.
There is also a video on you tube of a fellow in Labrador? working on /killing his End of Driveway Monster with his 624
that was his Christmas present.
Using a larger tracked machine without steering brakes just takes practice and patience and with a little higher speed you can use the machines speed to make turns at a fast pace by pushing against the snow caster=right to go left/ left to go right
to turn one way or the other then slow back down to work. If you have a little patch of ice and good boots with strap on steel cleats or sorrels you can work pretty well
I have seen videos of a tall skinny 120 pound Japanese woman using their(japan version 1028 model) moving it around while clearing snow.
There is also a video on youtube of a gentleman using his 1332 in very deep snows.
You have to decide what your time is worth, how much time you want to spend clearing and how your going to feel about clearing deep heavy snow with a smaller machine 5 or 10 years from now.
The 3 horse+ reserve of power in a 1028 will only help you in the future.
I am not trying to spend your money, just thinking about how your going to feel about snow clearing down the road.
Last edited by leonz; 02-04-2018 at 12:33 PM. Reason: stuff/spelling and punctuation corrections
leonz is offline
post #10 of 20 Old 02-03-2018, 04:23 PM
Coby7's Avatar
Likes (Given): 28
That 1028 is going to be heavier in 10 years too...
Coby7 is offline
