Yamaha YS624 Price? - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 06-11-2018, 03:40 PM Thread Starter
Yamaha YS624 Price?
I am looking at a non-running YS624. Pictures are attached. They are asking $350. What do you think is a good price in its current condition and then in Nov/Dec in running condition?
ID:	145417   Click image for larger version
ID:	145419   Click image for larger version
sr73087 is offline
post #2 of 20 Old 06-12-2018, 07:03 PM
Thanks (Received): 157
Likes (Given): 376
Likes (Received): 603
it looks like it would clean up ok.....but why is it non-running ? and its hard to tell from the pics, .....are the bottom edges worn off the bucket ? serrations gone off the augers ? if its not a toothless yammy, and it just needs a carb kit to run ( right), i would pay the asking price ! if the bucket and augers are worn , id offer a whole lot less and fix it for personal use . jmo
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Thanks sr73087 thanked for this post
post #3 of 20 Old 06-13-2018, 06:28 PM Thread Starter
Guy said it ran 2 years back. It sounds like he just let it sit. Seems like an older guy. He said he is selling it because he purchased a new blower.
sr73087 is offline
post #4 of 20 Old 06-13-2018, 06:50 PM
orangputeh's Avatar
Thanks (Given): 701
Likes (Given): 1177
Likes (Received): 1169
are those augers supposed to have serrations like they do on Honda's??? we have a member here named YSHSfan that knows these machines rather well but I think he is taking the offseason off from here. just like mentioned before, check the bottom of the bucket for damage and if it is maybe the augers are ground down which takes most of the value away in my opinion.
a Yamaha is a rare species in my neck of the woods. I would clean it up if not too damaged and clean out the carb, service it , etc and it would go for 2-3 times what he is asking during a snowstorm around here. depends on damage and further inspection.
I would offer 250 ( unless the bottom of bucket and augers are damaged ) I would also make sure the tranny was working thru all the gears.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #5 of 20 Old 06-14-2018, 11:29 AM Thread Starter
Ok so I picked it up for $250 last night. Bucket looked good, didn't see shoes on it though, not sure if it came with them. The auger did not look to have serrations like my Hondas do (HS55 and HS80). The other issues I noticed was a broken sheer pin on one side (no biggie) and what looked like some epoxy on the top of the tank, hopefully it holds fuel fine. Unit feels to have decent compression and has spark. There was fuel up to the carb inlet above the pump, not sure if there was fuel to the standalone "jet" on the engine side of the carb (see pics). What is this jet's purpose? However, there was no fuel in the carb bowl. Clogged inlet on the carb or sticking float? Carb looks pretty dirty/rusty inside but I haven't pulled it completely apart yet.
sr73087 is offline
post #6 of 20 Old 06-14-2018, 11:30 AM Thread Starter
Not sure why I couldn't attach the other pic on the last post.
sr73087 is offline
Likes jrom liked this post
post #7 of 20 Old 06-14-2018, 11:47 AM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 165
Great find!!!!!!!!!!!!!!!
For Orangeputeh, These beautiful models did not have serrated teeth originally when they were first introduced.
Plan on changing the fuel lines as they are always suspect and degrade over time.
I have a link in one of my posts to a Yamaha Dealer in Pennsylvania that has lots and lots of parts for old and new yamaha machines and you should chat with them.
If I remember correctly what another SBF member said you can replace the tracks with smaller Honda tracks.
You should also become a member of the Yamaha snow blower forum to learn more about your beautiful snow blower. there is no charge to become a member of that forum either.
if you can have the carburator dipped in an ultrasonic cleaner to clean it that will help you a lot another option would be to soak it in a deep bowl filled with alcohol or hydrogen peroxide for 24-48 hours.
Pipe cleaners should help you quite a bit when cleaning out the jets and fuel lines if they are metal.
Last edited by leonz; 06-14-2018 at 11:51 AM. Reason: stuff/spelling and punctuation corrections
leonz is offline
Thanks jrom, sr73087 thanked for this post
Likes jrom, aldfam4 liked this post
post #8 of 20 Old 06-14-2018, 05:35 PM Thread Starter
What does that secondary jet outside the carb actually do? I haven't seen that in any other blowers or other lawn equipment.
sr73087 is offline
post #9 of 20 Old 06-14-2018, 11:05 PM
leonz's Avatar
Likes (Given): 76
Most of them have 2 jets for low idle and high idle as far as I know but as most of my work was with large air cooled diesels it proved to me that indirect injection diesels are the simplest to own and operate all the way down to the Duetz 2 cylinder engines.
leonz is offline
post #10 of 20 Old 06-16-2018, 01:41 PM Thread Starter
Pulled the carb apart this morning and found a bunch of rust in the bowl, was able to get 95% of it out. Main jet was clogged as well as pilot jet, they came out and cleaned up nice . Tube below the main jet did not want to move even after spraying it with penetrating oil. Just sprayed the crap out of it with carb cleaner and did not want to mess with it since I do not see the replacement part for that available. Only other concern was the needle valve being alittle worn, but it seemed to seal when physically blowing through the fuel inlet and raising and loweing the float. Ordered a few new gaskets that were damaged or missing. Hopefully this thing fires up after $40 in overpriced parts.
sr73087 is offline
