Just picked up a YS624T - pics included - advice requested - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 11-13-2018, 09:21 PM Thread Starter
Question Just picked up a YS624T - pics included - advice requested
Sold my Ariens (subaru engine) to get a track and was mostly likely going to get a Honda HS55/HS80 but stumbled upon this unadvertised YS624. It was sitting for a year but started without too much trouble, the gentleman selling it takes in old mowers/snowblowers and this one came from the original owner heading south for retirement.
Any details specific to this year and model?
When I put it up in service mode do I need to remove the black extension on the bucket?
Do those shear pins look right or are they just bolts? I'll have to pull to be sure!
1st gear in forward and reverse doesn't work, I'm thinking the drive needs adjustment to move the clutch wheel more. I'll scan the forum for fixes.
I plan on replacing the oil, air filter, fuel filter, gear oil, plug, clean the carb without removing and disrupting hard to replace gaskets, inspect the belts and replace the fuel lines. Grease & lube of course. Anything else?
Next summer I'll sand down the rust, por-15 it and repaint with appropriate blue.
Thanks!
ID:	148469   Click image for larger version
ID:	148471   Click image for larger version
ID:	148473   Click image for larger version
ID:	148475   Click image for larger version
ID:	148479   Click image for larger version
mdistel is offline
post #2 of 21 Old 11-13-2018, 09:37 PM
JnC
JnC's Avatar
Thanks (Given): 62
Likes (Given): 26
Likes (Received): 213
Very very nice, i was lucky enough to purchase a wheeled YS624 a few years ago from its original owner as well. I think it was an 88 or 89 model, these machines are made to last with minimal care. Mine still had the original belts.
All I had to do was treat the metal tank with red kote to make sure it wont rust any further.
Looking at the rear mounted skid shoes I can assume that the augers still are in good condition.
My only recommendation would be to install some side mounted skid shoes to make sure the augers dont hit the pavement and wear down.
JnC is online now
post #3 of 21 Old 11-13-2018, 09:47 PM Thread Starter
Thanks. I've added a picture of the augers and I think they look great. So many of the Honda's I looked at had ground down sides and augers so your advice is reasonable! I'm going to adjust my skids so there is clearance from the drive. From what I've been able to find I need to look at parts for a YS624TE as that model has the plastic tank.
Mark
mdistel is offline
post #4 of 21 Old 11-13-2018, 10:41 PM
JnC
JnC's Avatar
Thanks (Given): 62
Likes (Given): 26
Yup, just what I thought, the augers are only very slightly worn, may be 10~20% i'd say, just throw on a set of Honda or any beefy side shoes and you should be fine.
Here is what mine looks like with the heavy duty honda skids. BTW the bucket is fully painted the rest of the body has OE paint on it still, I got lucky and was able to find a paint that matched the yamaha blue. I think it was this one
Name:	0-02-01-3974aad65dbbbfc906714d5fe55da256ec8f88b4d3677ef66bbe0108d5d2619a_full.jpg
ID:	148495   Click image for larger version
JnC is online now
Likes db130 liked this post
post #5 of 21 Old 11-13-2018, 10:50 PM Thread Starter
Your blower looks like new! if it weren't so cold I'd love to repaint before using but I'll have to just coat with fluid film this year. Thanks for the tip on the matching paint.
mdistel is offline
post #6 of 21 Old 11-13-2018, 11:36 PM
drmerdp's Avatar
Thanks (Received): 144
Likes (Given): 24
Likes (Received): 298
Very nice.
Ive been keeping my eyes peeled for a YS624. No luck yet.
drmerdp is offline
post #7 of 21 Old 11-17-2018, 06:44 PM Thread Starter
Some photos of the engine being removed to clean, replace the fuel lines, decarbonize and adjust the exhaust valve. Oddly there was no head cover gasket, I'm going to order one and install.
ID:	148657   Click image for larger version
ID:	148659   Click image for larger version
mdistel is offline
post #8 of 21 Old 11-17-2018, 09:08 PM
Coby7's Avatar
Thanks (Received): 111
Likes (Given): 29
Likes (Received): 724
Make sure all 3 auger bearings aren't dry and starting to rust. 6203 double seal, if you can get the precision even better.
Coby7 is online now
post #9 of 21 Old 11-17-2018, 09:45 PM Thread Starter
Thanks for the tip, I'll inspect those shortly. I'd like to grease the gears under the aluminum cover as well. I'm hoping I can remove the bolts and slide it back to access.
mdistel is offline
post #10 of 21 Old 11-18-2018, 05:50 PM Thread Starter
I did manage to add grease to the transmission gears. There's a plug on the side that gives access to the small gear that works but isn't ideal. Unfortunately there is no way to remove the cover without disassembling the majority of components. The tracks became smoother to turn after lubing the bearings and gears. Maybe one summer I'll disassemble and replace the bearings.
Fixed the gear shifting issue by replacing Bushing 90386-21126-00. After a bit of fiddling I managed to adjust the trans so all gears work.
Photos show some of the rust that's been treated. Next I'll coat with wax anti-rust and/or blue paint.
<arl
ID:	148715   Click image for larger version
mdistel is offline
