Yamaha YS1028J Battery Dead? - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 11-26-2018, 06:21 AM Thread Starter
I went out this weekend to get my snowblower ready for another NL winter season but it will not start. No cranking the oil light is not coming on in the control panel so I am assuming the battery is dead. Anyone have any specifics on the battery? Size? What charger have you used to charge yours in the past? What setting was the charge on? Thinking I will have to go buy a charger at Canadian Tire this evening because I don't want to leave it too long before I get it working again.
Bayman0625 is offline
post #2 of 12 Old 11-26-2018, 08:47 AM
Lunta's Avatar
Thanks (Given): 25
Likes (Given): 63
Likes (Received): 51
https://www.ctek.com/products/vehicle/xs-0-8
I just attached the cables to the battery, plugged the charger in and left it to it. I had it running maybe 4 times since last snow season, for 3 days at a time.
Battery was full of life when I fired it up a few weeks ago.
Lunta is offline
post #3 of 12 Old 11-26-2018, 09:07 AM
Coby7's Avatar
Likes (Given): 19
Likes (Received): 525
Did you try pull starting it? Leave it run for 15 minutes and see? I use battery tenders on all my seasonal stuff. It's not the money it saves that's important it's no aggravation each time you come to fire up your machine. I have 4 or 5 of these hanging around my garage. Lawn tractor battery is 10 years old or more still good, although I expect it's coming at the end of it's life, they don't normally last that long.
A battery charger is only good for charging a battery unless it has a battery tender option. These tenders are cheap on line from different sellers and most have de-sulfating circuits. Between $20-$40
Even though mine is a 624 it probably uses the same battery as the 1028.
Battery type YTX14-BS
Battery capacity 12Volt, 12Ah
# should be on the old battery if you killed it.
Here is the one I like, it has 2 types of quick disconnect.
https://www.ebay.com/itm/Battery-Cha...e/132549590036
Coby7 is offline
Likes JamesReady liked this post
post #4 of 12 Old 11-26-2018, 10:14 AM
leonz's Avatar
Thanks (Given): 72
Likes (Given): 75
Likes (Received): 152
There is no recoil start on the 1028 and 13332. :^((
leonz is offline
post #5 of 12 Old 11-26-2018, 10:35 AM
Coby7's Avatar
Likes (Given): 19
I did not know that!!!!! Learn new stuff everyday, maybe one more reason to get the 624...
Coby7 is offline
post #6 of 12 Old 11-26-2018, 10:40 AM
leonz's Avatar
Thanks (Given): 72
Likes (Given): 75
Send some of that famous cold weather and high winds down here to get rid of the clouds and rain and make the roads dry off to keep the temperature near zero Coby7!!!!!!!!!!!!!!!!!!!!!!!!!
I want this liquid snow crap to disappear!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
leonz is offline
post #7 of 12 Old 11-27-2018, 07:21 AM
I just picked up a NOCO G15000 which has a battery recovery mode. Itís a smart charger and one of the best you can buy on the market.
As mentioned above it is not a maintainer but they offer them as well including various adaptors for all things battery related. I plan on grabbing a maintainer for my truck. Also available at Cambodian Tire.
Worth the $ but if the battery is dead a maintainer wonít fix your problem. It may be possible to recover the battery but small engine batteries are pretty economical unless you are buying AGM.
J-Roc is offline
post #8 of 12 Old 12-03-2018, 05:20 PM
JamesReady's Avatar
Likes (Given): 26
Likes (Received): 9
Canadian Tire just had a sale on Tenders....from $45 down to $35... I'm like Cody and have 1 on the Goldwing/lawn tractor/wifes car. and now one on mt new YS624...
These tenders are great...Ö. Don't use a charger or it will boil it dry if you leave it on too long.
Good luck
I'm with you also, Leonz, I'm sick of the rain and sloppy snow......
1987 Craftsman Mod.C950528108 10/28...Techumseh Engine....SOLD
2007 Honda HS1132...GX340 Honda (Neighbor's)
2018 YT624EJ Yamahoooo..!
JamesReady is offline
post #9 of 12 Old 12-03-2018, 06:04 PM
Thanks (Given): 26
Thanks (Received): 67
Likes (Given): 89
Likes (Received): 122
For battery tender / trickle charger I have the Genius G7200. Leave it attached to my Mustang all winter for a trickle charge. It's one of the newer "Smart Chargers", so it keeps the battery in a fully charged state without overcharging the battery. Car starts right up each spring. Charges 12v or 24v batteries.
2009 Honda HS928WAS
2005 Honda HS520AS
1996 Honda HS621AS
2012 Toro 1800 Power-Curve
Freezn is offline
post #10 of 12 Old 12-13-2018, 01:57 PM
Snoopy's Avatar
Hello Fellow Bayman...
I had the same issue a couple few years ago.. The battery looses charge over the summer months.... Just put it on a battery tender for a few days and that will resurrect it - in most cases. These battery tenders are about $25- 30 at Canadian Tire, or any hardware store... And well worth the $.
When this issue occurred with me a couple of years ago, the Yamaha dealer told me to order and new battery and I did, from Honda One, as Yamaha would take 4 - 6 weeks to get it ordered. Anyway, a comparable battery cost me about $250.. Long story short --- I took the old battery home and put it on charge for several days and it worked. Still using it today, 3 yrs later. Just be sure to put it on the battery tender when the winter is over and it will be fine.
Snoopy is offline
