YT660 - Engine oil bubbling out of filler neck - Page 4 - Snowblower Forum : Snow Blower Forums
post #31 of 32 Old 12-22-2018, 10:14 AM
Thanks (Given): 20
Thanks (Received): 14
Likes (Given): 90
Likes (Received): 71
Originally Posted by 33 woodie View Post
just had the same issue on a troy bilt, leaked internally into the manifold into the bore via the intake valve,past the rings into the crankcase, the needle was gone,
new carbs seem to be unlike the olders for epa/carb gas vapor rules,
You fellows have made me a believer.
foggysail is offline
post #32 of 32 Old 01-22-2019, 02:21 PM Thread Starter
Lunta's Avatar
Thanks (Given): 33
Likes (Given): 112
Likes (Received): 68
Originally Posted by Lunta View Post
Daylight finally came and brought some snow. Oil change is now done (non-synthetic, thanks Mr Gibbs) and I closed the fuel tap and let it die out itself (thanks SkutFlut )
I'll monitor the situation and update results/solutions in case it helps someone else out.
No further problems encountered, everything is exactly like it was last winter.
I have been turning the fuel supply off and letting the motor die on its own.
Also... another Yamaha owner told me that they had engine oil bubbling out of the filler hole at the beginning of this season. So maybe it is a feature.... Certainly hearing that made me slightly less concerned.
Lunta is offline
