Yamaha YS624 chute turn problem - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 02-10-2019, 10:58 AM Thread Starter
Hi again.
I have discussed this one earlier, and tried spraying some CRC white grease lubricant between the Teflon collar and chute. But it still wont turn with the turn handle.
I made three videos about the problem.
First only turning the handle, no teeth from turn axle attached. There seems to be some play on the first joint:
Second is turning the chute with hand, no teeth from turn axle attached. It seems to get stuck on the middle (blowing snow forward) position:
Third is with turn axle theet engaged. It goes almost all right frfom turning the blower from right to left ( looking from the user position) but going back from left to right, it just gets stuck. And I must use force to get it move, and I fear something will break.
I cleaned all the white grease from all surfaces so now it is only the teflon collar contacting the chute base.
Is there anyway to fix this, it's really getting frustrating
blackis is offline
post #2 of 7 Old 02-13-2019, 04:28 PM
Likes (Received): 17
Regarding the u-joint binding (first video): I have placed washers under the cotter pin just above the joints to move the joint upward and thereby reduce the joint angles and resultant binding.
Regarding the chute binding: I don't know but would suspect something is assembled wrong
cpchriste is online now
post #3 of 7 Old 02-13-2019, 04:39 PM
Coby7's Avatar
Thanks (Received): 110
Likes (Given): 29
Likes (Received): 723
Or you may have a damaged tooth on the ring from an impact.
Coby7 is online now
post #4 of 7 Old 02-14-2019, 08:12 AM Thread Starter
I may have solved the problem. I put one steel washer under each 4 fasteners that keep the chute in place. So now the tefflon pads won't push so hard to the base ring of the chute.
I also used some cold weather grease on the bottom of the ring. Will post results tonight.
blackis is offline
post #5 of 7 Old 02-14-2019, 03:03 PM
Something is wrong there. The teflon pads each have a spring clip between them and the hold-down plate. This spring takes up the assembled GAP between the chute collar and the hold-downs. The hold-down/pad can never clamp down firmly on the chute collar.
Are the two anti-rotation "ears" on the the plastic chute collar fully seated in their slots? Is the chute base bent? Are the spring clips installed upside-down so their tips are digging into the pads?
post #6 of 7 Old 02-16-2019, 04:22 PM
Here's a picture of what I meant about adding washers to keep the u-joint properly aligned so it doesn't bind
post #7 of 7 Old 02-17-2019, 11:12 AM
GregNL's Avatar
Likes (Received): 19
CP's recommendation will most likely solve your problem. From the video you can see the multilink u-joint is binding due to the sharp angles. Add a little friction/tension from the chute and you lost the little play you did have at the worm drive for the U-Joint to slip around to push forward.
ID:	153667   Click image for larger version
YAMAHA YS624 |
GregNL is offline
Similar Threads
Yamaha YS624 in Colorado $300.00 obo russkat eBay Auction and Craigslist Links Section 11 10-11-2016 08:18 PM
My "New" Yamaha YS624 - Cleanup & Broken Engine Mount :-O LSxPoweredSorento Yamaha Snowblowers 4 09-28-2016 05:04 PM
John Deere Chute Problem brodie Snowblower Repairs and Maintenance Forum 3 02-02-2014 09:23 PM
Yamaha YS624 6HP engine RPM VintageYamaha Yamaha Snowblowers 2 12-15-2013 03:27 PM
HS80 - discharge chute rotation problem snow80 Honda Snowblowers 6 03-11-2013 05:09 PM
