Chute Problem - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 02-17-2015, 05:58 PM Thread Starter
Chute Problem
I have a rotation problem with my chute. If full left is 9:00 o'clock and full right is 4:00 o'clock Between 10 & 11 o'clock positions it skips. This happens when rotating left & right at the same spot. Give it a little nudge and it will continue to rotate. I've cleaned it and re lubricated it. It seams like its okay and doesn't appear to have any broken or excessively worn teeth. Anyone have any ideas?
bfc45 is offline
post #2 of 2 Old 02-17-2015, 06:02 PM
Thanks (Given): 30
Thanks (Received): 40
Ususally the chute rod worm gear is bolted in place there with slotted holes. Loosen and slide in a bit, then retighten. Should be good to go after that.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
