YS 240 TB transmission question - Snowblower Forum : Snow Blower Forums
post #1 of 23 Old 11-17-2013, 06:54 PM Thread Starter
db9938's Avatar
Likes (Received): 292
I am in the midst of putting a Ricky back together, but I do not have the owners manual or service manual.
Does anyone know what lubricant it calls for in the transmission/traction drive unit, and how much?
Any help would be much appreciated.
post #2 of 23 Old 01-14-2015, 10:52 PM
Thanks (Received): 137
Likes (Given): 202
Likes (Received): 287
DB
Did you ever get yours working?
This one came up in my area today. Ad says it's in great shape with nothing wrong.
Ricky in Utah
dbert is offline
post #3 of 23 Old 01-14-2015, 11:04 PM Thread Starter
db9938's Avatar
No.... I'm still trying to figure the trans out, when I get the time.
I read over on another thread, a guy that goes by JnC just bought one, and he got a service manual. I PM'ed him to find out where he found it, in hopes that they might have more. It would take all the guess work out of it.
post #4 of 23 Old 01-15-2015, 04:27 PM
JnC
JnC's Avatar
Thanks (Given): 60
Thanks (Received): 136
Likes (Given): 26
Likes (Received): 193
Unfortunately the gentleman only had one of the manuals. Here are some pages from the owners manual.
The "window sticker" i guess
owner's manual
Transmission oil change, seems like recommended oil is just 5W-30, nothing fancy
Electronic schematic
and here the page with all the pertinent info to specifications.
hope this helps.
JnC is online now
post #5 of 23 Old 01-15-2015, 06:00 PM Thread Starter
db9938's Avatar
Thanks for checking, the oil capacities and types I was able to pieces together. The electrical schematic is always good to have. I am surprised that there was no mention of the fluid type and amount, for the actual drive unit. There is actually a sealed section within the transmission, that selects the speed and direction, and it has it's own fluid. If you look on the right side of the transmission, you will notice a sight glass and a fill plug. The only suggestion I got, was to use John Deere general hydraulic fluid.
To give you an idea, of how far I had to tear this down, and maybe indication of what you would have to face, if anything where to happen.
ID:	36082   Click image for larger version
ID:	36090   Click image for larger version
post #6 of 23 Old 01-15-2015, 06:34 PM
JnC
JnC's Avatar
Thanks (Given): 60
Likes (Given): 26
You weren't kidding when you said you have the whole machine ripped apart. I'll get to that point eventually as well. I had read somewhere a common issue with the transmission, would you care to elaborate what that issue is? My machine surges every now and then, beside a carb rebuild can the fuel pump also be rebuild, or is it usually replaced? I'll post fluid type soon for the transmission, I am sure there I mention of it in the service manual.
JnC is online now
post #7 of 23 Old 01-15-2015, 10:01 PM
Likes (Given): 202
Service manual at ebay
YAMAHA SERVICE MANUAL YS240TBP LIT196160041 PRINTED 1990
Glad to know I can find one for $16 if I wanted one.
RE the trans fluid. in the document you photographed above it says
dbert is offline
post #8 of 23 Old 01-15-2015, 10:28 PM Thread Starter
db9938's Avatar
I saw the transmission fluid in your pics as being 5w-30. The drive unit within the transmission is a whole other matter.
This is the part that broke on mine. It retains the reluctor ring within the drive unit. It was buried. #3 on the diagram.
http://www.boats.net/parts/search/Ya...203/parts.html
The fuel pump is no longer available, sadly. And from what I noticed, it only has one part to go wrong, the diaphragm. And that's not available....I even tried to track down who made the unit, as it does not look like a Yamaha part.
The carb I believe, you can still find some parts too.
My take on this machine, as I have dug into it, was that for Yamaha was not making money on this machine. The amount of cast and machined parts that are contained in the transmission, had to make this thing a loss leader.
Especially when I compare this to other machines I've worked on, that can get the same job done, with less refinement or parts.
But I love a challenge, and this beast is just that.
post #9 of 23 Old 01-15-2015, 10:37 PM Thread Starter
db9938's Avatar
Dbert, I haven't looked in a while. And man did I just miss that one. Thanks for looking, I need to be more vigilant with keeping an eye out for one.
And from the picture, it's showing the rear of the machine, which is not where the drive unit is located. The drive unit is on the right side. It's under the air cleaner box.
post #10 of 23 Old 01-15-2015, 10:46 PM Thread Starter
db9938's Avatar
I will have to say one thing about these machines, I wish I could find a bulk supply of this fuel line that they used. After cleaning mine up, with some windshield fluid, it looked brand new, and was exceptionally supple without being gummy.
