auger shaft - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 12-13-2015, 07:03 PM Thread Starter
auger shaft
i have a ys624t (1987 i believe) and it has a cracked auger shaft at the keyway. i looked for a new one and found the part to be obsolete. i see a shaft for the newer models is still available but a different part number. i see the gear and bearings are the same number so the shaft diameter and gear housings are the same. the augers are different. all i can think of is the shear pin holes on the shaft might be different? any ideas on if i can replace with the newer model and just redrill some holes in the augers or get the one i have welded?
hate to junk a good blower
-Billy
billyham is offline
post #2 of 15 Old 12-13-2015, 07:21 PM
Thanks (Received): 723
Likes (Given): 4133
Likes (Received): 1583
Welcome to the forum Billy
Don't know about the new one fitting with some drilling but you should be able to have a machine shop weld and cut the key way back in.
Just not sure how much $$$ it might be.
You might need to drop in a couple shops to see.
Would like to see some photos of your machine and also the damaged piece if you get time.
Thanks billyham thanked for this post
post #3 of 15 Old 12-13-2015, 08:06 PM
Likes (Given): 467
Likes (Received): 480
-Billy
When you say a newer model, what exactly are you referring to?
post #4 of 15 Old 12-13-2015, 08:15 PM Thread Starter
1989 Yamaha YS624TA
Shaft, Auger
7KA-51646-00-00
billyham is offline
post #5 of 15 Old 12-13-2015, 08:52 PM
Likes (Given): 467
Could you post a few pics of your shaft and augers for comparison, I have a few plastic fuel tank YS624 (wich I assume are what you call later models)
post #6 of 15 Old 12-13-2015, 09:40 PM Thread Starter
attached are pictures of the snowblower, cracked/bent auger shaft and the auger.
hope the pictures are clear enough
thanks
-Billy
ID:	67186   Click image for larger version
ID:	67194   Click image for larger version
ID:	67202   Click image for larger version
billyham is offline
post #7 of 15 Old 12-13-2015, 10:09 PM
Likes (Given): 467
I'll look at them tomorrow and get back with what I find, can you measure the distance from the end of the auger "tube" to the shear pin hole on the augers and also, do they have the shear bolt on the auger housing side or on the gearbox end?
post #8 of 15 Old 12-13-2015, 10:25 PM Thread Starter
thanks
i will get a few measurements tomorrow morning. the shear pin is on the outer end of the auger
billyham is offline
post #9 of 15 Old 12-14-2015, 09:27 AM Thread Starter
good morning-
here are a few measurements for the auger:
outer end of auger to shear pin center 2 5/8
outer end of shaft to shear pin center 3 1/16
length of auger shaft 23"
thanks
-Billy
billyham is offline
post #10 of 15 Old 12-14-2015, 09:34 AM
Likes (Received): 279
hopefully somebody will have a good used one. try looking on CL for a non-running unit you could grab for parts. I don't see any parts for yours ebay at the moment. Keep looking - something will turn up.
