My "New" Yamaha YS624 - Cleanup & Broken Engine Mount :-O - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 09-28-2016, 12:36 PM Thread Starter
I just received this Yamaha ys625 from my dad it was moving to Florida. It runs amazing but has a little lost so I decided to clean it up a little bit. I was debating on if I was going to keep this for my MTD 5/24. However after taking some of this Yamaha apart and looking at the build quality I definitely know I'm keeping the Yamaha.
A little problem I discovered that while tearing it down was that the motor mount in the front is actually broke in half. It's a clean sheer right through the center of it so it looks like it's time to pull out the welder.
Here are a few pictures I took I will keep you posted.
Well I will post the pictures shortly. My post count isn't high enough. LoL
Figures.
Sent from my SM-G860P using Tapatalk
LSxPoweredSorento is offline
post #2 of 5 Old 09-28-2016, 01:58 PM
Thanks (Received): 374
Likes (Given): 466
Likes (Received): 477
I've seen a few Yamaha motor mount brackets cracked or repaired already, I'm going to have to assume that it is a common issue with them.
If you need a Service Manual you can find them on the following link, be patient and search through, they are there in PDF form for downloading.
Yamaha Snowblower Fan Club - Service Manual
post #3 of 5 Old 09-28-2016, 02:16 PM Thread Starter
Wow really? It's torn in a very odd pattern. I wonder if is just work hardening over time... The brackets are coated with something, I am assuming that it is galvanized. Thank God for HEPA filtration... That stuff is a no-go.
post #4 of 5 Old 09-28-2016, 04:00 PM Thread Starter
Here are the pics!
(I can finally post them)
I moved the bracket over just for this pic. It wasn't like this when i found it.
post #5 of 5 Old 09-28-2016, 04:04 PM Thread Starter
A couple nice close ups of the tear...
