Briggs gas tank retrofit on YS-624 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 10-29-2016, 11:06 PM Thread Starter
db130's Avatar
Thanks (Given): 16
Thanks (Received): 81
Likes (Given): 232
Likes (Received): 183
As you may know already, the gas tank on the 80s/90s vintage Yamahas is a weak point.
The metal gas tanks can rust from the inside out.
The plastic gas tanks develop a crack at the seams.
The replacement gas tank lists from Yamaha for $276!
There was a thread on Yamaha nabble about using a Briggs gas tank and it supplied part numbers:
Fuel tank p/n 799863 ~$50
Fuel tank bracket p/n 794801 ~$25
Screws p/n 699220 (qty 4) ~$2 each
Optional:
Control Cover p/n 696758 ~$10
My parts came from a Briggs engine that was run low on oil that was attached to a Simplicity snowblower.
First, drill 3 holes on the bracket so that we can mount the bracket to the top of the engine:
Next, mount the optional plastic cover:
The gas tank then can be mounted on the bracket using the 4 screws:
It doesn't look that out of place and even if all of the parts are purchased new, it's still significantly cheaper than the replacement Yamaha parts.
db130 is online now
Thanks YSHSfan thanked for this post
Likes dbert, detdrbuzzard liked this post
post #2 of 6 Old 10-30-2016, 02:59 AM
Likes (Given): 467
Likes (Received): 480
Thanks db130,
Do you know what is the B&S fuel tank capacity....?
post #3 of 6 Old 10-30-2016, 11:05 AM Thread Starter
db130's Avatar
Thanks (Given): 16
Likes (Given): 232
It is from their Intek series and the listed fuel capacity on the Inteks that use this fuel tank is 4 qts=1 gallon.
db130 is online now
post #4 of 6 Old 10-30-2016, 11:27 AM
Likes (Given): 467
Thanks db130.
post #5 of 6 Old 09-23-2018, 02:20 PM
Bringing this back from the dead. Quick question, it looks like the 3 bolts holding down the new bracket were originally from the Yamaha setup. Is that correct, you just reused the old hardware from Yamaha to mount the new bracket?
sr73087 is offline
post #6 of 6 Old 09-30-2018, 05:04 PM
Ok so I did this install. Just clarifying for anyone else who does this.
-The 3 bolts holding the tank bracket are 2 cylinder head bolts and 1 smaller cover bolt.
- The optional cover needs to be trimmed
-The OEM fuel shutoff is mounted to the tank, so if you want a shutoff you need to purchase an inline 1/4 one for this setup.
Also, keep in mind the way it is installed above flips the tank around and has the fuel line on the carb side. Make sure you mock up the bracket to leave clearance from any moving parts.
sr73087 is offline
