624 Skid adjustment question - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 11-05-2017, 03:44 PM Thread Starter
Likes (Received): 6
The owner’s manual indicates adjusting the skid so the auger is 5 mm above the ground. It also indicates to adjust the scraper so it is 5 mm above the ground. That makes the auger and scraper on the same level. Does not make sense to me.
I think the scraper should be between the skid and auger. Maybe they should all be 5 mm apart?
bcjm is offline
post #2 of 2 Old 11-11-2017, 12:46 PM
Likes (Received): 14
Why? The skids should be the only thing touching the ground and the scraping blade even or lower than the auger blades. Now if the scraper was higher than the auger I would think ***!
The Q is offline
