New auger cable too long - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 17 Old 02-01-2020, 12:24 PM
Thanks (Received): 208
Likes (Received): 764
go to the hardware store ...get a couple of small cable clamps, fold up the cable to take up the unneeded slack, clamp with two cable clamps, wrap some tape around it and call it a day.
cranman is offline
post #12 of 17 Old 02-01-2020, 12:47 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Given): 466
Likes (Received): 811
OP didn't say if this was working before, or any history on it. I wonder if the Pulley Assembly on the lower chassis is Missing....
The Ignore List Takes out the Trash
Jackmels is online now
post #13 of 17 Old 02-01-2020, 01:04 PM Thread Starter
squid3083's Avatar
Likes (Received): 16
Originally Posted by RedOctobyr View Post
Any pics you could share would probably help the rest of us. For instance, if the extra length was in the housing but also the cable, then, if it was like a bicycle cable, that wouldn't matter. Those are located using the ends of the housings, so extra cable & housing length just means there is more of it flapping in the breeze, but wouldn't cause a problem.
But I'm guessing that's not how yours mounts, since clearly the extra length is an issue here. So pics showing the cable and where it attaches might be helpful.
Look at my first pics. One end is crimped to a sleeve that a screw goes inside to the handle. The other end goes into a spring with a ball at the end with a hook.
The hook attaches to a lever next to the auger pulleys. Not too much room to put my fat fingers.
squid3083 is online now
post #14 of 17 Old 02-01-2020, 01:22 PM Thread Starter
squid3083's Avatar
both pulleys are there and it is working but streched a bit and the sheath underneath both pulleys is warned and cable is rusted.
pulley in front on the left next to the pulleys for auger belts.
other pulley back of snowblower left.
post #15 of 17 Old 02-01-2020, 01:24 PM Thread Starter
squid3083's Avatar
cable clamp would work also, and would be the best. Just have to see if there is enough space between the pulley for the auger belt and frame of auger.
post #16 of 17 Old 02-01-2020, 01:39 PM Thread Starter
squid3083's Avatar
space where I need to hookup the spring with end of cable.
post #17 of 17 Old 02-01-2020, 01:44 PM Thread Starter
squid3083's Avatar
other plastic pulley in front bottom right of pict
Name:	other puloley 33.jpg
