Got this Ariens Yesterday with a Leaky Gearbox. Drained the Oil, and Filled with 00 Grease. Problem Solved, 5 Minute Fix. This gearbox was Easy to Fill from the Front as Pictured. If you have to Fill into a Plug Hole, it will take a While. 00 grease, about $5 qt. at TSC.
For those looking for it here are some numbers from my recent search.
NLGI “00” Grease / Sept 2018
Oregon 4049H 32oz $18.30 Amazon
Prime line SME 706612 32oz $13.49 NAPA
Prime line PRI 7-06612 32oz O’Reilly
Stens 770-123 32oz $17.72 Amazon
Super S SUS 111 32oz $4.99 Tractor Supply
John Deere AN102562 14oz tube $5.72 Amazon This one is NLGI Grade 0
Thanks to both of you for the info! Though Jack, it looks like the driver's side auger is reversed, and would push the snow in the wrong direction?[/QUOTE
Thanks, I'll check it. Just got it in Yesterday.
ive used JD cornhead grease in many gearboxes , from snowblowers to antique outboards.....never had an issue of any kind....it truely is an easy cheap fix .
