Hi everyone, I decided to do the Predator repower. All is going well except trying to figure out how to shift the worm gear over so that the crank can move to the outside of handle bars (so it does not hit the engine). What has everyone used in the past to facilitate this? Thanks
Discussion Starter · #4 ·
Thanks for the suggestions.
DB, for the bottom image with the eyebolt, did you find the worm gear to slip a bit on the teeth for the chute? I wonder if the gear needs to be moved slightly to keep it firmer to the teeth.
