1 - 3 of 3 Posts
I just bought a 11528 it's a 926102 with the bicycle lever release for unlocking the left side wheel from the axle.
I did a repair to the release, that turned out well.
But I noticed when doing the repair that the axle bushings or bearings, (whatever is in there) have a large amount of play.
Is there a spec for replacement? And are they an easy change?
It looks as if you could remove the wheels and swap them without removing the axle.
Should be Easy. Remove Wheel, and 3 bolts removes the bushing/assy.
If you can feel play in it, and it is easy to replace, "Just Do It" ! Can't cost that much for the part, and it will provide peace of mind, or if it goes bad - "piece" of mind !
1 - 3 of 3 Posts
